Tip & How-To about Audio Players & Recorders
Never leave an image on a DLP tv, It will burn into the screen
Ok I had a problem with a banding on a 57 inch sony DLP, It was burn in from thr ticked that runs on CNBC when I was trading everyday. It took the 8 months to return the set after 6 tries at trying to get me to accept it, The ended up changing all 3 guns, the power board, and the front glass which they cracked one time and scratched the second,I was on a first name basis with the VP from the chain store. She was a very nice lady and we became friends. Meanwile the final time the forgot to scre the wheels back on, so they called 2 more techs to tilt it while one screwed in the wheels. Two days later the same thing happened, the VP told me they had spent over $2000.00 dollars on a 1,500.00, dollar tv. She sent me a gift card for a new set and that was that, Both Dlp's and Plasmas will, Burn an image onto the screen within 15 minutes. I only suggest LCD tv's. Especially if you pause things and forget or they are on, video games, especially, you will surelly screw it up. There may have been a ticker scrolling or a paused show on your set and it may be burned into the screen or gun itself. Even pictures from your camera will do it, most manufacturers leave themselves an out even on the sets tha say they are burn in proof. Do,not buy Plasma or DLP tv's, they all have burn in problems even if the salesman tells you different, A simple search will bring up hundreds of articles from folks who were not made aware of this.
How to change electric cord on Sears Band saw
You should check the manual of your band saw. Or just call the manufacturer directly.
Apr 17, 2013 | Olson Bandsaw Blade 57 56-7/8 Inch 1/4 X...
I'm looking for replacement bandsaw blades for a McGraw-Edison 10" Bandsaw, M/N - T6760. Any Ideas?
I have 11[6 tooth scrolling blades] & 3[3/8" 14 tooth general purpose metal cutting blades.T8380-16 & T8382-16 for McGraw Edison 10" bandsaw. blades are 57" been hanging in my garage for past 25 yrs lol. would like to sell to best offer. contact me at tazzdh1959@yahoo.com
Feb 24, 2011 | Saws
What is the band saw blade length for a JWBS-20-1 Jet Band saw.
The 20 inch band saw uses a 150 inch blade and I'm envious. The 20 inches refers to the wheel diameter
For more information:
http://www.redmond-machinery.com/Jet%20JWBS-20.htm
I'd gladly trade.
Feb 20, 2011 | Garden
I have had a Sony KF-WS60S1 rear projection TV for some 3 years and recently had to replace the globe. I completed this as per the book, double checking all screws were tight and the globe inserted correctly. 3 months on, I have a 6''high x 4''wide triangle of blue light in the bottom LH corner as you look at the screen that bleeds across the bottom of the screen about1/2''high. I have also noticed that there is now a horizontal band across the middle of the screen where the reds are slightly more pronounced, probably about 6-8''wide. Please help as we really have enjoyed the quality of the tv picture over the years
You will need to pull out the engine and check for any smudge on the lens. then proceed with the polarizers 3 of them they are sitting in front of the DLP chips, this is a delicates operation. the blue polarizer is the one which usually suffers burn-in (dark spots on the glass). if everything looks ok, then it means that the dlp chips are faulty, at that stage it will be uneconomical to be fixed.
Hope this helps!
please rate me!
Mar 19, 2009 | Sony Televison & Video
316 people viewed this tip
 Grubhead
Grubhead
