Tip & How-To about Computers & Internet
Antivirus system Pro, removal, how to.
It is best if you perform the following steps when your computer is operating in safe mode. You can select safe mode by pressing the F8 or F10 key just before the operating system is about to start. Once in safe mode open up the Task Manager, head over to the processes tab and end any of the following processes if you see them listed:
antivirussystempro.exe
uninstall.exe
antivirsystempro.exe
sysguard.exe
You can also use rkill, which is a fantastic little utility that can detect and terminate a number of malware processes automatically.
Next up its time to delete files that Antivirus System Pro created when it made a home on your computer. Keep in mind that some of these files may be locked by the application and may not be possible to simply delete them. You can use Unlocker to remove such files or folders. Also you might need to run the command “regsvr32 /u iehelper.dll” before you can delete that file.
Program FilesAntivirus System PROquarantine.vdb
Program filesAntivirus System PROqueue.vdb
Program filesAntivirus System PROmbase.vdb
Program filesAntivirus System PROconf.cfg
Program filesAntivirus System PROuninstall.exe
Program filesAntivirus System PROAntivirussystempro.exe
WINDOWSsysguard.exe
WINDOWSsystem32iehelper.dll
Documents and SettingsXXXXsysguard.exe
Finally, you need to dive in deep and delete some values from the registry. To do so, open up the run dialog box by pressing the key combination Win + R and then type in regedit. This will open the registry editor.
You will see HKEY_CLASSES_ROOT, HKEY_CURRENT_USER, HKEY_LOCAL_MACHINE, HKEY_USERS listed in the left side pane. These are the trees which contain values created by various software and the operating system to run properly. Antivirus System Pro also makes certain entries to the registry, which should be deleted for complete removal. The entries are listed below:
HKEY_LOCAL_MACHINESOFTWAREAntivirus System PRO
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionUninstallAntivirus System PRO
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun “Antivirus System PRO”
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionShellServiceObjectDelayLoad “ieModule”
HKEY_CURRENT_USERSoftwareAvScan
HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun “system tool”
HKEY_CLASSES_ROOTCLSID{BAD4551D-9B24-42cb-9BCD-818CA2DA7B63}
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerBrowser Helper Objects{BAD4551D-9B24-42cb-9BCD-818CA2DA7B63}
Ok, this should have gotten rid of that horrid virus.
Computers & Internet Logo
dos prompt flashes up
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Apr 21, 2013 | Dell Dimension E520 PC Desktop
T6216 will only boot in safemode
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 26, 2013 | Computers & Internet
I am running in safe mode, I computer will only let me go back one day, this problen started ten days ago.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. If you need more help with this post a reply
Hope this helps.
Jan 19, 2013 | Microsoft Windows XP Home Edition
operating system not found
1.Try restarting the computer in safe mode, keep tapping the F8 key as soon as you restart the computer and then from the advance boot options select the safe mode option to boot the computer to safe mode.
2. If the computer boots to safe mode perform a system restore.
3. If issue persists, reset the BIOS to defaults and then try again.
4. Verify if the hard is detected and listed in the BIOS setup. (press F2 at startup to enter BIOS).
5. If hard drive is detected and listed with its capacity such as 300/5oo GB, then, perform system recovery using the F10 recovery partition.
6. Restart the computer and start tapping the F10 key immediately to enter the system recovery partition, then, select the Rescue data option to backup the data from computer if any available or select the restore C drive option to perform system recovery and restore computer to factory settings.
You can also perform a memory diagnostics before performing the recovery.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1000582
If the hard drive is not listed in BIOS with its capacity, contact Sony service team to get the hard drive replaced.
If the computer is brand new, you can try exchanging the notebook with a new one.
Nov 09, 2010 | Sony VAIO Notebook
Keeps shutting down.
To resolve the issue, Please perform the following steps:
Step 1: BIOS Reset
To reset the BIOS defaults, follow these steps:
1. Restart the computer and press F2 (F10 in some Notebooks) as soon as the HP logo appears.
2. Go to Exit menu and select Load BIOS defaults or press F9.
3. Go to Exit menu and select Save changes and Exit or press F10.
This will reset the BIOS defaults. Now, when the Notebook restarts, press F8 repeatedly until the start up menu appears. Select the Safe Mode and press Enter Key to enter in Safe Mode and then perform the step 2.
Step 2 : Disable the "Automatically Restart" under System Failure:
1. Click Start, right-click the My Computer icon, then Properties.
2. Click the Advanced tab, then Settings in the Startup & Recovery section.
3. Remove the check mark next to Automatically Restart under System Failure.
4. Click OK to close the Startup and Recovery window, then click OK to close the System Properties window.
5. Restart the computer.
Step3: Reinstall Power management
To reinstall Power Management in Windows XP, follow these steps:
1. Click Start, select Control Panel, and then choose Performance and Maintenance.
2. Click the System icon to open the System properties window.
3. Select the Hardware tab and click Device Manager.
4. Click the plus (+) sign next to System Devices.
5. Right-click the ACPI Fixed Features button and select Uninstall.
6. Restart the system.
On restarting the system, Windows will automatically detect and install Power Management on the computer.
May 25, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
232 people viewed this tip
David Payne
David Payne
