Tip & How-To about Computers & Internet
Key Disk for Toshiba laptops Some Toshiba notebooks allow to bypass BIOS by inserting a "key-disk" in the floppy disk drive while booting. To create a Toshiba Keydisk, take a 720Kb or 1.44Mb floppy disk, format it (if it's not formatted yet), then use a hex editor such as Hex Workshop to change the first fwe bytes of the second sector (the one after the boot sector) and set them to 4B 45 59 00 00 (note that the first three bytes are the ASCII for "KEY" :) followed by two zeroes). Once you have created the key disk put it into the notebook's drive and turn it on, then push the reset button and when asked for password, press Enter. You will be asked to Set Password again. Press Y and Enter. You'll enter the BIOS configuration where you can set a new password. .
Computers & Internet Logo
downloadable windowsxp boot disc winxp setup process
Windows XP Professional
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=55820EDB-5039-4955-BCB7-4FED408EA73F
or
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
Step 2: Run the Setup disk program to create the Setup disks
When you download the Setup disks, the download contains only one large program file. When you run the downloaded file, it extracts the files. You receive the following message:
This program creates the Setup boot disks for Windows XP. To create these disks, you need to provide 6 blank, formatted, high-density disks.
Please specify the floppy drive to copy the images to:
Type the drive letter for the floppy disk drive (this is typically drive A). After you type the floppy disk drive letter, you receive the following message:
Insert one of these disks into drive drive letter:. This disk will become the Windows XP Setup Boot Disk.
Press any key when you are ready.
When you press a key, the downloaded file starts to extract and copy the files. Continue to insert the blank disks as you are prompted to do this until all six disks are created. If the process is interrupted, you must run the downloaded program file again to create all six disks.
Make sure that you label each disk appropriately with the number that is specified by the program. You must use the disks in the correct order during the Setup process.
Step 3: Start your computer by using the first Setup disk to begin a new Windows XP installation
After you create all six disks, insert the first disk in the floppy disk drive, and then restart the computer. The computer must be configured to start from the floppy disk drive. You may have to modify the BIOS settings on your computer to do this.
The Setup process starts. Insert the other floppy disks when you are prompted. You must use the Windows XP CD-ROM to finish the Setup process.
hope it helps
May 20, 2012 | Iwill XP4 Barebone
it keep asking for a password as soon i turn it on
There is only ONE FREE way, and that is to make and use a Key Disk for Toshiba laptops.
Or one can take it to an authorised service center, and for a price, and with proof of ownership, they will unlock your unit for you
Nov 15, 2010 | Toshiba Satellite L305-S5933 Notebook
how can i reset the bios password for this laptop?
Key Disk for Toshiba laptopsSome Toshiba notebooks allow to bypass BIOS by inserting a "key-disk" in the floppy disk drive while booting. To create a Toshiba Keydisk, take a 720Kb or 1.44Mb floppy disk, format it (if it's not formatted yet), then use a hex editor such as Hex Workshop to change the first fwe bytes of the second sector (the one after the boot sector) and set them to 4B 45 59 00 00 (note that the first three bytes are the ASCII for "KEY" :) followed by two zeroes). Once you have created the key disk put it into the notebook's drive and turn it on, then push the reset button and when asked for password, press Enter. You will be asked to Set Password again. Press Y and Enter. You'll enter the BIOS configuration where you can set a new password..
Jul 10, 2010 | Toshiba Satellite A10-S177 Notebook
How to format a Toshiba M100
get a win 98 boot disk floppy. set bios to read floppy or usb floppy first save and exit. insert disk and boot comp. select boot without cd rom support. At command prompt type " FDISK " then hit enter dont type quotes. delete the particians then create new partician set 1 particians as active then remove disk then insert OS disk and go forth. I after you install your new OS and you get two boot options at the command promt after loading type " delpart " and delete the particians and save (use the tab and alt keys to bring up menus save and exit before you leave delpart) reboot and run fdisk to creat a partician and set it as active. then load your OS
Jun 10, 2009 | Toshiba Satellite M100 Notebook
687 people viewed this tip
David Payne
David Payne
