Tip & How-To about Computers & Internet
PANASONIC FM, FC series caps for repair
For repairing switching power supply, mother board, LCD TV/Monitor. These caps are made for switching power supply, it has low ESR, high ripple current handling, 105c rating.
Panasonic caps from DIGIKEY
http://dkc3.digikey.com/PDF/US2010/P1648.pdf FM series
http://dkc3.digikey.com/PDF/US2010/P1645.pdf FC series
http://dkc3.digikey.com/PDF/US2010/P1646.pdf FC series
Capacitor kits: http://lcdalternatives.auctivacommerce.com/Default.aspx
http://www.illinoiscapacitor.com/pdf/Papers/low_ESR_fact_or_fiction.pdf
Computers & Internet Logo
What type of capacitor I need for the power board
105C rating, low ESR (a must for switching power supply circuits) type.
I use PANASONIC FM or FC series from DIGIKEY, or you can order the kit from here:
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VA2026W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Aug 20, 2011 | ViewSonic VA2026w Monitor
I have a gateway desktop monitor with the model number FPD 1960 TFT LCD COLOR MONITOR. The power does not come on after you switch on. When I opened and checked I discovered that power does not go into the low voltage area from the high voltage area. Again I saw two swollen capacitors in the low voltage area. I wonder where the problem is.
So you can see at least two bad caps, then you need to replace them, there should be a set of caps for the 5v power supply for the logic circuits and the set of caps for the16~18 vdc power supply for the backlights inverter circuits.
http://s807.photobucket.com/albums/yy352/budm/GATEWAY/
Make sure to use low ESR type caps.
Read my guide to understand how LCD monitor works.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jul 13, 2011 | Gateway HD2201 22" LCD Monitor
My LG26CL2D power supply now make a squerling noise after I replaced 3 ea. bad cap. Any advice on this one.
Correct polarity and you use low ESR type not generic electrolytics from RADIO SHACK? Low ESR is a must for switching power supply. Also bad cap can look normal but can have high ESR.
http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/?action=view&current=DSCF0262.jpg
Should also recheck your soldering work just in case.
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | LG 26LC2D 26 in. LCD Television
dell 1800fq LCDcomputer monitor not coming up
More likely to have shorted out SWITCH MODE POWER SUPPLY IC, very common in this power supply. You can replace the power supply or buy a repair kit for this power supply on EBAY.
You should at least finr out if your are getting the 12vdc at the power supply output connector.
Replacement power supply module:
http://lcdrepair.us/1800fp-power.html
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Jan 05, 2011 | Dell UltraSharp 1800FP 18.1" LCD Flat...
E176FPb REPLACED C703 AND C704 STILL FAILS DISPLAY AFTER 3 SECONDS POWER LIGHT REMAINS ON
You need to find out if you do have 12vdc and 5vdc for the inverter circuits and logic board, I usually repalce the caps in a set not just the bulging one since bad cap can look normal but has high ESR, you need to use low ESR type cap in switching power supply, generic Radio Shack will not work or last very long. I use Panasonic FM/FC series for all my repair works because it has low ESR, 105c and high ripple current and high rated life.
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Replacement board: http://www.lcdrepair.us
Please post back what you find.
Nov 10, 2010 | Dell E176FP 17" LCD Monitor
873 people viewed this tip
David Payne
David Payne
