Tip & How-To about Video Game Consoles & Games
How to repair a scratched disc
Disc are always getting scratched; well there may be a way to clean them up. This may sound a little far-fetched, but but toothpaste on the disc and spread it out evenly, then let it sit for about 10 minutes. Then carefully rinse the disc with water and clean with a soft cloth.
This process could possibly be successful with peanut butter as well.
This worked for me a couple of times, I hope the same for you!
Good Luck!
Video Game Consoles & Games Logo
CDS slipping when playing.
Try the disc in another CD / DVD player.
It is important to make sure that the DVD itself is the problem, and not the CD / DVD player.
Cleaning a CD / DVD player is a much more intricate process that requires device-cleaning hardware.
Lay the disc artwork-side down so that you can easily clean the playing side.
You should always avoid setting a disc playing-side down to prolong its lifespan.
Gently rub the disc with a soft, lint-free cloth to remove all traces of dust and fingerprints. Always rub a disc from the center toward the outer rim in a light motion to prevent any other damage.
Apply a light amount of toothpaste to a cotton wool ball and gently rub the disc from the inside out.
You may need a few drops of water to make the toothpaste spread easily.
Cover the entire surface area of the disc, or at least the area that is scratched.
Toothpaste is a gentle abrasive that works well for fixing simple scratches.
Clean off the toothpaste with the cloth, once again rubbing from the inside of the disc toward the rim.
Try not to push too hard to prevent further damage.
Apply other kinds of light abrasives such as baking soda or glass cleaner if the sound is still distorted.
Remove the solution with the same gentle rubbing technique.
Purchase a disc-cleaning spray from a local video or electronics store.
These sprays are effective in removing any grime from the disc and filling small scratches.
hope this helps
Sep 30, 2012 | Philips Fwm608/12 600W Subwoofer Mini...
fwm608 CDS slipping when playing
hope this helps
Vice City plays fine, but when i take that out and put in fifa '08, it goes to that configuration screen, with a picture of each memory card, and the disc. If I click the disc, nothing happens
That means the cd is not reading. Carefully clean the disc and put it back in. Start the game and if it comes on again, press the reset button and see if it will plat this time. Might have to do it 2 or 3 times, but if it is going to play, it will come on.
Mar 01, 2011 | Sony PlayStation 2 (PS2) Console
the disc is unreadable
Is it just dusty, or are there scratches?
If it is just dust, clean is with something soft- t-shirts work quite well ni the abscence of anything else.Make sure to clean from the middle to the edges in lines, not circles.
For small scratches, a sometimes very useful solution is toothpaste.Put some toothpaste by the scratch and rub it it, then wash of excess toothpaste and dry the disc.The toothpaste fills in the scratch, leading to a temporary fix.
May 16, 2008 | Video Game Consoles & Games
461 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
