Tip & How-To about Microsoft Windows Vista Ultimate Edition
How can uninstall And re installed ie7 in windows vista
Pls help me how can uninstalled in ie7 in windows vista business
Microsoft Windows Vista Ultimate Edition Logo
Missing tool bar when I uploaded to Explorer 7. I cant click on tools to get it back because I dont have a tool bar to acces
Try to uninstall IE7. Once it's removed, restart your computer then it will revert back to the older version IE6. After that you can opt to install IE7 again or much better a newer version like 8 or 9.
To uninstall IE7, kindly follow these steps:
  1. Close all programs.
  2. Click Start and then click Control Panel.
  3. Click Uninstall a Program under the Programs category
  4. In the Tasks pane, click View installed updates.
  5. In the list of installed updates, double-click Windows Internet Explorer 7. In the Uninstall an update dialog box, click Yes.
    Note If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
  6. Follow the instructions to uninstall Internet Explorer 7.
  7. When the uninstall program is finished, restart your computer.
  8. After you restart your computer, open Internet Explorer. Click Help>About Internet Explorer and check if it's on version 6. If it is then proceed with upgrading to a higher version again.
    Hope this helps.
Nov 18, 2011 | Microsoft Internet Explorer 7
Windows Mail won't check for new mail and when clicking on Send/Receive it tells me there were errors. However, if I just click on Receive All it will download the mail. I am using Vista Home Premimum.
could be ur broswer! i use IE7 cause its older and useing less cpu power to run! all new browsers look better but then they actually decrease the online performance as olders things now are messing like ur mail not loading so i say try useing IE7 and of you have 8 than i say downlaod IE7 then uninstall IE8 and then install IE7! i love IE7
Dec 24, 2009 | Microsoft Windows Vista Home Premium...
Ever since upgrading to Internet Explorer 8, I find that I cannot print emails, open up many attachments, and retrieve other information. For example, if I click on a link, I get the following message: "Internet Explorer has stopped working. Windows will close the program and notify you if a solution is available." At the bottom of the screen, there is also an error message. My OS is Windows Vista. Can anyone recommend a solution to this problem? Thanks so much for your help.
Ther are known conflicts with Vista and IE8 - particularly with Vista 64-bit.
I would suggest uninstalling IE8 and reinstalling IE7 or using an alternative browser such as "slimbrowser" (excellent program) or similar.
IE8 can be uninstall by using Add or Remove Programs module in Windows XP, but in Windows Vista, Windows Internet Explorer 8 is not considered to be a ‘program’. Instead, IE8 is categorizing as an ‘update’. Thus, users will not be able to find Windows Internet Explorer 8 in “Programs and Features” of Windows Vista.
To uninstall Internet Explorer 8, go to Control Panel, and click on Uninstall Programs link or Programs and Features icon. Then on Tasks pane on the left, click on View installed updates link. Locate and select Windows Internet Explorer 8 in the list of installed updates, and then click on Uninstall button. Click on Yes when asked that are you sure want to uninstall the update.
If there is no option of IE8 been found on “Programs and Features” or “Add or Remove Programs” dialog box, or uninstallation of Internet Explorer 8 is unclean (causing error message such as setup cannot continue because a more recent version of Internet Explorer has been detected on this computer when trying to downgrade to IE7), try to manually run the spuninst.exe.
To do so, go to C:\WINDOWS\ie8\spuninst\ folder (your drive letter may be different), and run spuninst.exe.
Restart the computer after uninstallation completed.
Hope that helps :)
Nov 09, 2009 | Dell Studio XPS 435 PC Desktop
Uninstall ie7
thank you for the clarifiaction it seems that you cannot uninstall IE in Vista, but you can disable it. If you go to the control panel, and double click on "default Programs" the last of four options will be "Set Program Accesses and Computer Defaults". Tell the User Account Control prompt to "continue", then click the radio-button by the "custom" option, and then hit the expand arrows to the far left, it'll take you to a bunch of options. the first is "Choose a default web browser". If you [i]un-check]/i] the box by Internet Explorer, you will pretty much only be able to access it through the "run" prompt, if at all, and no third-party programs will open links in IE.
hope it helps!
Nov 05, 2008 | Microsoft Internet Explorer 7
installed ie8 and want to go back to ie7... need help pls...!!!
uninstall ie8 and reinstall the ie7. the setup file for ie7 is available in the link given below.
http://www.microsoft.com/windows/downloads/ie/getitnow.mspx
Aug 15, 2008 | Computers & Internet
308 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
