Tip & How-To about Denpa mp-36 128MB Handheld Digital Voice Recorder
DENPA MP38FM problem affter upgrade
I have
DENPA MP38FM 1G kit with external FM mic.
Problem is affter upgrade software from cd which was in the kit, now I lost some icone on the LCD screen. Looks like big screen but small LCD. Need Help with right upgrade software.
Thank you
Denpa mp-36 128MB Handheld Digital Voice Recorder Logo
DENPA WAV FILES CORRUPTED!!
Hi Guys,
I have the same corrupted file, but you can recover it by using the GoldWave software. Just type"Goldwave" in google, follow the link and download the software, install it. From that software open the corrupted file, and then save it as a new copy. ( It will fix the problem when opening the file, where you can see it). They try to play the new saved file, shld be fine.
all the best.
Oct 30, 2007 | Denpa USB-24 Digital Voice Recorder
telephone recording
Yeah, um connect it to a phone in a room that is normally isolated from traffic. Not an ideal solution but as it is a machine and has only an external mic (it doesn't have an internal mic does it?) this is the only solution really, remove all noise except phone conversations.
Sep 25, 2007 | Denpa USB-24 Digital Voice Recorder
Denpa USB - 24 DVR
Give me an ftp address and I'll upload the software. I have the same voice recorder. unsafeagent@yahoo.co.uk
Sep 14, 2007 | Denpa USB-24 Digital Voice Recorder
Denpa drivers required for online download
Depends what OS you are using. If you are using Windows ME/2000/XP/Vista then you do not need drivers for device to be recognized by PC when it is connected via USB cable (operating system will automatically work out what drivers are needed and configure so that the PC 'sees' the device - once seen it will show up in my computer as 'removable disk' icon).
If you are using Win98 then you need to install the driver. I haven't found anywhere on the Web where the files are located but they may be on the Windows 98 CD itself (they are identified as HB_UDISK_DRIVERS).
For example, from the installation CD the full path would be:
D:\HB_UDI~1\WIN98\HB__UDISC.INF where the CD-ROM drive is called the D drive (depends on hard disk configuration).
There is another question on here where someone has posted a link to a site to download software...not sure if the device driver files are available there. Note that the drivers merely enable your PC to recognize the device - the won't be any use in encoding/decoding/editing the files; that's done by separate software programs.
Good luck. Repost if you're having no joy...I may be able to dig out my installation CD and burn/mail you a copy. I'll check back in a week or so.
Nov 10, 2006 | Denpa USB-24 Digital Voice Recorder
806 people viewed this tip
Top Denpa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denpa Audio Player and Recorder Expert? Answer questions, earn points and help others
