Tip & How-To about Computers & Internet
How to assemble computers?
Its really a simple thing to assemle the computers if you know some simple tips to do that.The first step is to connect the 'smps','DVD writer','harddisk' and 'mother board' to the cabinet.After that all the connections should be given properly as per the diagrams given in the booklet provided.Then the processer and fan should be fixed properly.And then install the Operating System.
Computers & Internet Logo
pointer works until I login, then sticks in middle of screen. Help?
They say to err is human, but to really mess things up takes a computer. Nothing is more frustrating than to have a computer freeze, shut off with no warning, or, worse, crash completely. One of the more common errors a PC will give you is the freezing of the monitor. With a few simple troubleshooting tips, you can overcome that.
Press Crtl-Alt-Delete (at the same time). This will give you a box generally used to terminate programs. Using the arrows, if you can, shut down all programs running (i.e., Word, Internet Explorer, etc.). Sometimes, it is an error within the programs or with your computer trying to process them all at once that causes your computer to freeze. This is especially true if you have low RAM (anything less than 500 or so MB or RAM). Turn off your computer and restart it. Many times this will end whatever error up above was causing it to drag. If the computer is still frozen when it comes back on, go on to the next steps. Press the tower's power button and hold on to it until the entire system shuts down. Turn off the main power switch and turn it and the computer back on. Sometimes a computer only looks like it is shutting down, but in actuality is not. This should solve the problem. If it doesn't, move on to the next steps. step 4. Try a different mouse. If you have a mouse that connects to a PS2 port, the mouse could be bad. If the mouse doesn't work in that port, the port may be bad, too. Many times people only think their computer is frozen, but really the mouse doesn't work. step 5. Try connecting a USB mouse into a USB port. If it works, you now know that either your PS2 mouse or port are bad. If you have a USB mouse to begin with, try connecting it into another USB port, since the original port may be bad. Try Steps 4 and 5 for the keyboard as well. Take it to a computer doctor, or to the technical department at the store where you purchased it. If none of the above work, you have a bigger problem on your hands. Your computer may be in the initial stages of crashing.
Feb 03, 2013 | Toshiba Satellite Computers & Internet
my son used to watch our sony dvd player he knows how to operate it one sunday when my husband want to watch movie he cant open it our dvd player had locked so we cant open it and cant operate it when we want to view
Unfortunately if the door is latched but with power then the loading motor section is struck or failed. If there is no power at all the power supply unit has failed. you will need to check on the SMPS unit . Check my tips column for SMPS maintenance.
Sep 14, 2010 | Sony DVP-FX810 Portable DVD Player
How to fix my computer PC so noisy
check the noise location.
It could be the internal fan or it could be the CD/DVD drive making noise.
You probably have to open the case/Tower to check what is causing the noise. If it is a fan make sure it is not obstructing with any wire and then close the tower carefully.
It could be the SMPS( switched mode power supply ) the power supply of the computer. SMPS is the box inside the tower where the power cable of the computer gets connected.
Try to check if that is making noise or not .. If it is get that replaced.
If it is a CD/DVD ??
check if the noise comes when the CD is in or it comes even if it is empty.
Both cases the CD/dvd drive needs repair.
Try the steps above and let me know if you have any other question.
May 10, 2010 | Sony VGC-LT32E PC Desktop
I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
Are you trying to connect to the wireless network on the laptop ?
It is very simple.
first you will need to make sure that you have all the wireless settings of the network.
Click Here for more info about wireless network connections
Oct 17, 2009 | Belkin (F5D5231-4) Router
Wife put new password and now in the hosopital. Need help unlocking
its very simple to open it when urs computer stsrt ommediatly press F8 for a while then ur computer shows fallowin wndow ...
it includes starting windows safemode, command prompt etc etc
select safe mood ur computer start automatically widout ny password then in safemode u can make other account in user account..
then can eaisly acess ur computer....
ask me if dere is ny other problem occurs..
Jun 18, 2008 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
156 people viewed this tip
David Payne
David Payne
