Tip & How-To about Computers & Internet
How to burn AVCHD Lite to DVD on Mac OS X?
AVCHD-Lite, which is a subset of the AVCHD format popularized by hard disk camcorders from Sony, Panasonic, and Canon, uses h.264 video coupled with AAC audio for recording movies. AVCHD Lite video is currently used by Panasonic DMC-ZS3, Panasonic DMC-FZ3, Sony, Cannon AVCHD Lite Camcorder, etc.
The main differences between AVCHD Lite and the regular AVCHD: a maximum resolution of 1280 x 720p in AVCHD Lite compared to 1920 x 1080p in regular AVCHD and a less-intensive compression method - both of which make the format more suitable for less powerful camera hardware.
What you need to burn AVCHD Lite to DVD on Mac OS X?
Neither of AVCHD and AVCHD Lite video is directly supported by iMovie or iDVD on Mac OS(10.6.3 Snow Leopard included) if you want to burn AVCHD Lite to DVD. There are 3rd-party solutions that work with varying degrees of success in allowing you to work with AVCHD Lite video on Mac, like Daniusoft DVD Creator for Mac . It is DVD Burner that can convert AVCHD Lite video to DVD. With it, you can add DVD menu, edit videos and pictures, add transitions and effect, etc.
Below is the step by step guide on how to burn AVCHD to DVD on Mac OS X
Step 1. Load files Just click “+” button to import AVCHD Lite files to this program or simply drag and drop them to it. And rearrange the file list by using the up-down arrows.
Tips: You can freely drag and drop the thumbnail to merge or split the video files.
Step 2. Edit files (Optional) To personalize your DVD files, you can edit the video files by clicking “Edit” button. For video files, you can crop the frame size, trim into several clips, append effects, add picture/text watermark and rotate.
Step 3. Create DVD Menu (Optional) This Mac DVD Creator also allows you to create your own DVD menu with rich selections of DVD menu template. Simply click “Menu” button to select one and set the “Frame”, “Button” and “Text” to customize your DVD menu.
Step 4. Start to burn After all necessary settings, you need to insert a blank or rewritable disc to your Mac if you want to burn video files on DVD disc. Or you can simply convert the videos to DVD folder, .dvdmedia or ISO file on your Mac for later burning.
That is it! Within several clicks, you can burn AVCHD lite to DVD easily. So, why not download Daniusoft DVD Creator for Mac for a try?
Computers & Internet Logo
AVCHD to H.264 converter-Visualize videos on MacBook,iPhone 4 While you have .mts or .m2ts files from AVCHD camcorders of your friends or relatives, you may find it difficult to visualize the AVCHD videos on your iMac, MacBook Pro or iPhone 4. AVCHD is the advanced format for shooting videos in high definition with 1920x1080 or 1440x1080. Most AVCHD camcorders record HD videos in .mts format, while there are some in .m2ts format like Sony HDR-SR5. Sony HDR-CX110, Sony HDR-XR520V and Canon HF S21, Panasonic HDC-TM700K and the like offer AVCHD videos in .mts format. While QuickTime Player does not support playing AVCHD videos, VLC media player may sometimes has problem with AVCHD videos, a quick Mac AVCHD to H.264 converter is needed to make MTS/M2TS videos visible on MacBook and even iPhone 4. Aunsoft MTS/M2TS Converter for Mac is the best AVCHD to H.264 converter, which transcodes videos to Mac compatible MP4 format and deinterlaces AVCHD for playback on Apple computer and iPhone 4. Below is the step-by-step guide for converting AVCHD MTS/M2TS to H.264 on Mac Snow Leopard for you to play HD videos on iPhone 4. Step 1. Load AVCHD videos to Aunsoft MTS/M2TS Converter for Mac. After transferring .mts or .m2ts files from AVCHD camcorder to computer hard drive, run Aunsoft MTS/M2TS Converter for Mac as the best Mac AVCHD converter, and click the "Add" button to load HD 1080p AVCHD videos. Step 2. Choose H.264 format. For Full HD playback on iMac/MacBook Pro, just click the "Format" option and choose HD Video > H.264 HD Video(*.mov) or choose .mp4 output format. The output H.264 videos will play on Mac without problems. If you want to play HD video on iPhone 4, just choose iPhone > iPhone 4 H.264 720P(*.mp4) for converting AVCHD to 720p MP4 for iPhone 4 with H.264 as video codec. Step 3. Convert AVCHD to H.264. Click the convert button under the preview window, and the Mac AVCHD to H.264 converter starts transcoding AVCHD MTS/M2TS to MP4 for playback on Mac OS X and iPhone 4. The Mac AVCHD to H.264 converter deinterlaces and removes interlacing artifacts of the 1080i videos for smooth playback on computer and portable devices. You can then watch the HD videos on MacBook, beamer and iPhone 4.
Aug 03, 2010 | Cell Phones
Mac Sony DSC-TX7 to iPhone 4 Converter-Play MTS on iPhone 4 I just bought Sony Cyber-shot DSC-TX7 camera and like to play with the new AVCHD recording, which is the spotlight comparing to previous Cyber-shot cameras. It is good to know that PMB Portable is built into the camera for easy transferring and downloading videos to hard drive. But I could not play the AVCHD video on iPhone 4. The AVCHD video from Sony TX7 is in .mts format, which is not recognized by iTunes, let alone to iPhone 4. I googled for solutions to sync AVCHD videos to iPhone 4, and found Aunsoft MTS/M2TS Converter for Mac the perfect Mac Sony TX7 to iPhone 4 converter. Besides converting AVCHD to iPhone 4 MP4, it also downscales the video resolution from 1920x1080 to iPhone 4 compatible 720p. If you have similar problems for playing camera HD videos on iPhone 4, just follow the steps below to convert AVCHD videos on Mac Snow Leopard and enjoy videos on iPhone 4. Step 1. Load Sony TX7 HD videos to Aunsoft MTS/M2TS Converter for Mac. After transferring Sony TX7 AVCHD video to computer hard drive, just run Aunsoft MTS/M2TS Converter for Mac as the best Mac Sony TX7 to iPhone 4 converter, and click the "Add" button to load HD 1080i AVCHD videos. Step 2. Choose iPhone 4 MP4 format. Click the "Format" option and choose iPhone > iPhone 4 H.264 720P(*.mp4) for converting 1080i Sony MTS to 720p MP4 for iPhone 4 with H.264 as video codec. Step 3. Convert 1080i MTS to iPhone 4 MP4. Click the convert button and the Mac Sony to iPhone 4 converter starts transcoding 1080i MTS to iPhone 4 MP4. Wait until the conversion is finished, and it is easy to sync Sony videos to iPhone 4 via iTunes then. Aunsoft MTS/M2TS Converter for Mac helps you convert Sony AVCHD videos to iPhone 4, and AVCHD videos from Canon camcorder, Panasonic camcorder to iPhone 4.
Aug 02, 2010 | Cameras
177 people viewed this tip
David Payne
David Payne
