Tip & How-To about Televison & Video
Is your remote really DEAD?
Hello again, I am here to try and put together tips here at Fixya.com "TO SAVE YOU MONEY".
Is you remote really dead?
Have you tried these steps?
1. Pull the batteries out of the remote and leave them out until Step 4.
2. Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
3. If your remote has buttons, they may be stuck go to step 2.
4. Put the batteries back into the remote
5. New batteries should be used if you're not sure about the old ones.
Try the remote.
You also can try taking it apart "things do get in between the buttons". So what you can do is take the button pad out and clean the debris inside. You can use 90 percent grade alcohol or even electronic circuit board cleaner bought from radio shack.
If it still does not work then the chances are you need to check into www.remotes.com for a new factory remote. You can also use any universal remote that will not break the budget.
I will update my tips as time goes on and as I experiment with actual dead remotes but until then follow these steps it will save you money and frustration.
It would be considerate of you to consider all tips from all experts and also casting you vote for us. We are on this forum to help save you money! We only want your vote is your truly satisfied, Thanks
Televison & Video Logo
remote does not work
Remotes devices are heavily depened on it CPU chip,might the CPU chip is shorted and dead the remote is garbage.Tries take the remote aparts,take some Q tips dipping in some rubbing alchahol clean the PCB board and inner rubber layers,wait like about 20 mins. than putting it back together again put in brand new batteries,might get the remote to work again.Not try website like Remotes.com to buy an original or very close to the original remote.
Jan 06, 2011 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
remote stop working. is there some way to fix the problem?
Tries to take the remote aparts,cleans the PCB board and the battery - + connections with some Q tips dipping in some rubbing alchahols,than wait like about 20 mins,put the remote all back together again and put in new batteries.The remote,should work now,if not it garbage the main CPU probally shorted and dead,because remotes devices are heaviest dependent on the CPU chip.Try website like Remotes.com to buy an exact oringinal remote or very close to it.
Dec 09, 2010 | LG 42LC2D 42 in. LCD HDTV
Cannot turn tv on or off remotely. Tv works fine after turning on manually.
Take the remote control aparts,take some Q tips dips it in with some rubbing alchahol.Clean the remote control PCB board,putting it back together again,wait like 20 mins.Put in new batteries.The remote now should work again.If not it garbage,because it CPU chip is dead.Try website like Remotes.com to buy an exact remote to ur original remote.
Nov 18, 2010 | Quasar VV2007 20 in. Combo
The remote control for our 26C3030 Toshiba television has stopped working. None of the buttons work and you have to function the televsion manually by using the buttons on the actual tv. We have tried swapping the batteries several times and still does not work. We are wondering of there is anything else we can try before buying a new remote. Thanks
Most of the time the remote CPU is shorted and the remote is dead.But some time by taking the remote aparts,by cleanning the PCB board with some Q tips dipping in with some rubbing alchahol.Wait like about half hour,put the remote together again tried it,might work again,might not.Not,try website like Remotes.com to buy an exact remote to ur original remote.
Oct 26, 2010 | Televison & Video
I have a tv remote control and it has new batteries why won't it work?
Take the remote aparts,take some Q tips dipping in with some rubbing alchahol clean the PCB an check the - + battery connections,might be rust on them,clean it with some WD40 to take care of the rust.After this wait like 30 mins and put the remote all together again.The remote now,should work.Not,than the remote CPU is dead.Try website like Remotes.com to buy an exact remote to the original remote.
Oct 23, 2010 | Televison & Video
580 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
