Tip & How-To about Computers & Internet
Annoyed that your Num Lock key isn't on when you start your PC?
Here's a quick tip to ensure your numlock key stays "ON" by default when the computer starts.
1. log off your PC to the Ctrl-Alt-Del screen
2. Turn on the NumLock key
3. Hit Ctrl-Alt-Del (like you are about to log on)
4. Don't log on, hit the "shut down" button to turn off your PC
This saves the numlock key in the "ON" position by default when the PC starts.
Computers & Internet Logo
How do I get past theYour pc will restart in 2 days to finish installing important updatesIt won't let me enter my password to unlock the pc
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order
If this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jun 23, 2013 | Acer Computers & Internet
My desktop 4210 is in paused mode how do i fix it
Step 1:
Restart your computer During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys Acer: - Ctrl +Alt +Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc) Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 12, 2013 | Computers & Internet
proper booting up, what needed to type f4 or f2
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced Bios features press Enter you will see what the boot order is set to.
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
If you are unsure on what the boot order should be you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order.
Dec 01, 2012 | Microsoft Windows XP Professional With...
booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
Sep 27, 2012 | Sun Blade 2500 PC Desktop
floppy drive
You're talking about My PC and device manager and I'm talking about Bios.
The BIOS (stands for Basic Input/Output System) is system software inside your computer that helps the computer start up, even before Windows does. It also contains key settings about what the computer has on board.
In newer computers, it exists on a special chip called CMOS (stands for Complementary Metal Oxide Semiconductor).
You can go into the BIOS to edit or change the technical information about key components of the computer like disk drives, keyboards, and display settings. It also keeps track of the date and time.
The BIOS can normally be accessed when you start your computer. You may see a reference to "Setup" when you turn your computer on. That’s your opportunity to get into the BIOS. It usually requires the push of a function key, such as F10, to get access to it. That "F" key varies between computers. Sometimes it’s not even one of the Function keys, but the ESC key or DEL key.
If a logo screen—like HP or Dell—is displayed during the start up process instead, then you may want to check with your computer maker for a command to turn off that screen and display the start up information, which is listed when a computer is powered on.
A partial list of BIOS access commands by brand is listed at the end of this article.
The BIOS also contains the boot-up sequence. Normally, computers are configured to boot from a hard drive.
Before you do anything to your BIOS, it’s always a good idea to record the original settings on a sheet of paper that can be kept in a safe place so you can reference it later if you need to reset it.
Here is a list of key sequences for various brand-name computers. If yours is not there, check with your manufacturer or watch for info flashed on-screen when your computer first starts, before Windows begins. It may say
"For setup hit..." That will be how to get into the BIOS on your machine.
ALR PC: (F2) or Ctrl+Alt+Esc
AST, Advantage, Award, Tandon: - Ctrl+Alt+Esc
Award BIOS: (Del) or Ctrl+Alt+Esc
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during boot up.
Aptiva - Press F1
IBM PS/2: Ctrl+Alt+Ins after Ctrl+Alt+Del
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or Ctrl+Alt+Esc
Phoenix BIOS: - Ctrl+Alt+S
Phoenix BIOS: - Ctrl+S
Phoenix BIOS: - Ctrl+Alt+Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl+Shift+Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift+Ctrl+Alt + Num Pad Del
Miscellaneous PC’s: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl+Alt+Ins
Let me know how it is going!
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
206 people viewed this tip
David Payne
David Payne
