Tip & How-To about Computers & Internet
All drivers for mainly all PC hardware
Here is a link to a webpage with a huge database of drivers, firmwares and manuals of many devices you can find in a computer. Cheers!
Computers & Internet Logo
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
I was listening to the player and it all of a sudden wouldn't shut off and it wouldn't charge, after 2 days it charged and i was able to get into the files but it wont let me delete the files and says my memory is full and it also wont turn on now it just says building database over and over again for about 3 minutes before shutting off.
When the Sansa Express keeps freezing you can RESET the device using next step:
note:
The device can be either on or off, player NOT connected to the computer:
Press and hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
When the "rebuilding database" message keeps coming back, the player will need an update.
Use the Sansa Firmware Updater (works on Windows only) or go for the matching download on the forum:
http://kb.sandisk.com/app/answers/detail/a_id/446/kw/database/p/555%2C662%2C687/r_id/101834
The Sansa Firmware Updater will contain the driver for the computer to perform a firmware update on your player [ METHOD 1 ].
When downloading the driver package manually, first put the driver "StMp3Rec.sys" in the correct folder on your computer. Next start the SansaExpressUpdater [ METHOD 2 ].
During this update, connection between player and the computer is based on MTP mode, Media Transfer Protocol: Drivers and software are needed to get access to the player.
The player could also be accessed in MSC mode, seeing the player as a removable disk. How to get connection in MSC mode, see next link:
http://www.machinist-toolbox.com/SansaExpress_MSC-Mode.pdf
Manual for Sansa Express:
http://mp3support.sandisk.com/downloads/um/express-userguide-en.pdf
Support site for the Sansa Express:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC9nWWpkcGYqag%3D%3D/sno/0#express
May 19, 2010 | SanDisk Sansa MP3 Player
135 people viewed this tip
David Payne
David Payne
