Tip & How-To about Grilling
Gas flame burning yellow?
Does your grill or pool heater have a yellow flame instead of blue? If your propane tank is not just about to run empty, then you can probably thank little spiders.
When a gas burning appliance sits idle for a week or more outdoors, spiders like to build nests in the venturi tubes (that's the tube with the holes in it where the combustion air gets sucked in). This changes the way the combustion air mixes with the gas and causes the gas to not burn completely. The incomplete combustion is not very hot, and so the flame appears yellow. This is not efficient. It wastes gas, is too cool for grilling steak and creates soot residues. This is very common on gas grills (bottled propane or piped natural gas). It also happens to pool heaters.
Fortunately, the fix is easy, and you usually don't need to take anything apart. Get a piece of stiff nylon string from a weed-wacker, about 12 inches long. With the burner cool, push the string into any hole in the venturi tube and spin it by rolling it between your fingers. The spider nests are sticky (made from the same stuff as spider webs) and they usually adhere to the nylon string.
Not sure what the venture tube is? It's going to be between the valve and the burner. The valve shoots a stream of gas into the venture tube through a pinhole nozzle called an "orifice". You can do a Google image search for BURNER VENTURI TUBE to see lots of different types. Every gas burning appliance uses some form of venturi tube.
Good luck. Al K
Grilling Logo
The side burner flame is always yellow and does not adjust high to low. Always high & yellow. How do I adjust to get the hot, blue flame
Aug 17, 2010 | Garden
Table top propane heater: tank freezes, fire goes out
I have a table top heater and was wondering why I have flame shooting out of the top of it when I should have like a blue flame, what can I do
Dec 14, 2009 | RTO Bernzomatic Brushed Nickel Patio...
propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
2,379 people viewed this tip
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
