Tip & How-To about Computers & Internet
Solution on a slow Internet connections Problem  The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.  1. Broadband Router Settings As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.  2. Wireless Signal Interference Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.  3. Internet Worms An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.  4. Running Background Applications Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.  5. Faulty Network Equipment When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.  6. Service Provider Issues Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.    www.temabcomputerssolution.blogspot.com
Computers & Internet Logo
pc performance is poor
A slow internet connection could be caused by any number of reasons.It may be connection or Traffic problem.To increase your internet speed use the following tips given below:
1.Clear cookies from your Browser.
2.Delete unwanted files.
3.PC Optimization:
It is important to clean your PC regularly.It means a normal maintenance tasks such as, cleaning the disks, registry repairs and Disk management.
4.If you are using DSL Connection over your Landline, make sure that you have high quality filters in place to get optimus signal speed.
5.Upgrade your modem.
6.Use updated Browser.
7.Consult with your Internet service provider to ensure that your modem is configured correctly.
8.Replace your telephone modem with a fast-access connection such as wave,ISDN,DSL,Satellite,a cable modem.
9.Tweak your router settings.
10.Install Antivirus Software.
11.Reduce your Bandwidth overhead.
Still your internet speed is slow then, Contact your ISP and get latest speed plan from them.It's better way to increase internet speed.
After completing this steps, you can check your internet speed whether increase or not using this site ScanmySpeed.com
Mar 18, 2014 | Samsung XE303C12-H01US CHROMEBOOK 11.6"...
why is my acer z5700 very slow when i go to internet?
the navigation on the internet is not restricted only by the computer's performance but the connection type also ..It very much depending on the connection speed..and if you use a slow one..it is the case.Usually the slow function is cause by the use of wireless connections from mobile phone providers..or wrong settings in wireless router..
if this is the case ..try the direct connection with the cable and make a speed test on the internet ..you should have a speed specified in the agreement with the ISP ..if this is very slow ..you should check for causes..Either the connection is damaged or you have a wrong settings somewhere ..
Jul 21, 2011 | Acer Aspire Z5700 PC Desktop
bought a new comp woith windows 7, when i try to watch t.v. it keeps buffering, can u help me tyvm
First check to see that you have known good bandwidth on your internet connection. If this is slow, you will always run into a situation where your playback is running faster than your download rate and causing your streaming software to pause and buffer content before continuing.
I'm assuming you connect to the internet via wi-fi, try connecting to the internet through a cable & see if that helps.
Unfortunately the Presario CQ62-215DX does have problems with poor video streaming capabilities (frequent freezes) and poor wi-fi performance which is probably the cause of your buffering problem.
Hope this is of some help. ;)
Feb 02, 2011 | Compaq Presario CQ62-215DX Laptop
slow internet
I'll advise to try an all-in-one Mac speed up software as it can help resolve all issues in just a few clicks. That's it!
Jan 23, 2011 | Apple MacBook Air
macbook pro and belkin router
Can you check if you have problems with your internet connection?
How about your browser? i recommend using mozilla firefox browser because i assure that it it the fastest browser.
If you have no problems with your internet connection probably you may want to check if your device are working properly.
Consider:
The type of Internet connection you use is the most important factor in determining your connection speed. The three most common ways to connect to the Internet from home are dial-up, DSL, and cable. If you have a choice, cable is usually the fastest, but both DSL and cable are faster than dial-up.
The health of your computer can affect your Internet connection.Spyware and viruses can definitely cause problems, but your Internet connection speed can also be affected by add-on programs, the amount of memory the computer has, hard disk space and condition, and the programs that are running.
Two of the most frequent causes of poor Internet performance are spyware and viruses. Spyware can slow your system by interfering with your browser and monopolizing your Internet connection. Spyware monitors your Internet use and keystrokes, which adds delays. The problem is compounded when there are multiple spyware programs running at the same time. If the problem is severe enough, you can lose connectivity altogether. To get your Internet performance back, you should regularly run an antispyware program to clean out any spyware infestation.
Computer viruses can also cause poor Internet performance. When a virus infects a computer, it installs computer code which will attempt to propagate itself, usually by sending copies of itself through e‑mail. Some viruses can multiply at the rate of hundreds of e‑mail messages per minute, which leaves little computing power and Internet connection bandwidth for anything else. Viruses often do not give any obvious indication that they are running, so it is best to run your antivirus software at all times.
Thank you : ) i hope my information works.
Please pm me if none of the options work. :)
Aug 08, 2009 | Belkin (F5D72304F5D7000) Router
1,076 people viewed this tip
David Payne
David Payne
