Tip & How-To about Computers & Internet
FLAsH yOuR KeyBoard Lights
Hey it is very simple to do this. You have to just copy following information in the notepad and save it as " flash.vbs" on desktop. After this you have to just run that exe.
Code:
Set wshShell =wscript.CreateObject("WScript.Shell")
do
wscript.sleep 100
wshshell.sendkeys "{CAPSLOCK}"
wshshell.sendkeys "{NUMLOCK}"
wshshell.sendkeys "{SCROLLLOCK}"
loop
Computers & Internet Logo
How to Make a Popup (for Windows)?
Open Notepad (Start>Programs>Accessories>Notepad).
Copy and paste the following text into the program: lol=msgbox("",16,"Error")
26319026-bxzhjmonsmllydp0qa2riq2g-2-2.jpg In between the two adjacent quotation marks, type the error message you wish to appear in the popup (eg. lol=msgbox("Example",16,"Error")).
Click File>Save As. 26319026-bxzhjmonsmllydp0qa2riq2g-2-9.jpg In the 'Save type as' dropdown, change the setting from 'Text Documents' to 'All files'. Then, as your file name, type your file name (when you open the file, it will trigger the popup), followed by '.vbs' (eg. Example.vbs). Then, in the 'save in' dropdown, select a place where you can access your file. When you have selected your desired place to save the file, click 'save' to save your file.
Open 'My Computer' (Start>My Computer) and find your newly-created file.
Open the file, and your error message should pop up on the screen!
Oct 20, 2016 | Microsoft Computers & Internet
how to make usb background?
you can easily do it in simple steps:
follow these steps: 1.in a notepad type this-[ExtShellFolderViews] {BE098140-A513-11D0-A3A4-00C04FD706EC}={­BE098140-A513-11D0-A3A4-00C04FD706EC} [{BE098140-A513-11D0-A3A4-00C04FD706EC}] Attributes=1 IconArea_Image=123.jpg
or just copy and paste it in a notepad and save as desktop.ini 2.select file/ image you wish for your background and rename it to 123.jpg for example 3.copy the two files you made and paste to your usb device.then refresh.
Feb 10, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I am not able to edit my basic info.
Hi, what basic info exactly are you talking about?
Computer owner / organisation?
If you would like to use a script to change your owner / organisation, please follow the steps below.
NOTE: Executing a .VBS script is usually not a good idea, unless you know what you are doing. Please carefully follow the instructions below.
Below is a custom script made to change your owner/organisation.
Press Start->Run
type notepad.exe, press Enter
copy and paste the following:
'ChgOwnOrg.vbs - Change Win9x Registered Owner/Organization.
'© Bill James - billjames.geo@yahoo.com - rev 29 Oct 1999.
'Modified for Windows XP
Option Explicit
Set ws = WScript.CreateObject("WScript.Shell")
Dim ws, t, p1, p2, n, g, cn, cg
Dim itemtype
p1 = "HKLM\Software\Microsoft\Windows NT\CurrentVersion\"
n = ws.RegRead(p1 & "RegisteredOwner")
g = ws.RegRead(p1 & "RegisteredOrganization")
t = "Change Owner and Organization Utility"
cn = InputBox("Type new Owner and click OK", t, n)
If cn <> "" Then
ws.RegWrite p1 & "RegisteredOwner", cn
End If
cg = InputBox("Type new Organization and click OK.", t, g)
If cg <> "" Then
ws.RegWrite p1 & "RegisteredOrganization", cg
End If
--- Stop copying here. DO NOT COPY THIS LINE ---
If you feel at all unsure, do not run this script. All it does it change your Owner and Organisation of the computer.
Save that file (in notepad) as "Change Info.vbs"
Note that you will have to change the "Save as type" to "All Files"
After you are done saving it, close notepad and double click "Change Info.vbs" and it will ask you to enter first your name, and then your organisation.
If this wasn't what you were asking about, or if you don't want to run a .vbs script (I can understand), please let us know.
Dec 14, 2009 | Computers & Internet
Funny UST Scandal
hi my friend got that last week to... ehat you need to do is download kaspersky. after running kaspersky. that will be gone. you can download kaspersky @ majorgeeks.com Here are some examples of autorun viruses which rely on the autorun function of Windows to infect PC’s and flash drives. Funny UST Scandal.avi.exe Autorun.vbs win32.autorun.k copy.exe imgkulot taga lipa are autorun.vbs recycler FS6519.dll.vbs strawberry from baguio W32/Perlovga (copy.exe | host.exe) VBS_RESULOWS.A Bha.dll.vbs w32automa worm (Autorun.vbs) Trojan.Win32.VB.atg | Win32/Dzan | Worm_vb.bnr (tel.xls.exe | mmc.exe) W32/RJump.worm (RavMonE) Worm.Win32.Delf.bf | W32.Fujacks (spoclsv.exe) W32.Fujacks.BH (****.vbs) WORM_AGENT.PGV (soundmix.exe) W32/Hakaglan.worm (RVHost.exe) Trojan.Win32.VB.ayo [AVP] (Macromedia_Setup.exe) Trojan.VBS.DeltreeY.b#1 (Destrukto!!! | destrukto.vbs) if you want to manually delete it... Solution is here: 1. Start Notepad [Start Menu-All Programs-Accessories-Notepad] or right-click any empty space in your desktop then select New-Text Document 2. Copy the following text. (note: Everything in between the square brackets should be in one line) REGEDIT4 [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionIniFileMappingAutorun.inf] @="@SYS:DoesNotExist" 3. Save the file with a name (anything) like DisableAutoRun.reg (The extension .reg is the important part) 4. Double Click your newly created registry file. Choose yes or continue to the warning that will appear. hope this helps
Jan 24, 2008 | Computers & Internet
195 people viewed this tip
David Payne
David Payne
