Tip & How-To about Computers & Internet
Network Windows 7 with Xp and Vista
Windows 7 includes a new way to share data between all computers in the house with the Residential Group. But only when computers running Windows 7 may join the Group residential and enjoy the new features of sharing, playing multimedia files remotely, etc.. If you have computers running Windows XP or Windows Vista networking with Windows 7, you can still share your files and printers in Windows 7 "old" by following the instructions in this case practice. Below are the steps to do the same.
Check the workgroup:
To be a network, your computers with XP, Vista and Windows 7 should be part of the same workgroup.
Click the Start button. Right-click Computer (My Computer in XP) and click Properties.
In the Settings area of the computer name, verify the name of the working group. The default name is WORKGROUP but you can customize it by clicking the Change Settings button.
Make sure it is the same on other machines on the network. Under XP, the information is in the Computer Name tab.
Enable Sharing:
To enable sharing in Windows 7, you must change the settings of the Network and Sharing Center.
Click Start, then Control Panel.
Click Network and Internet and then click Network and Sharing Center.
In the left column, click Change sharing settings advanced.
Verify that the options Enable network discovery, Enable file sharing and printer sharing and Enable so that anyone with network access can read and write are checked.
Click Save Changes.
Computers & Internet Logo
Cannot able to change Home-group password in Windows 7.
Go into control panel then go to home-group there should be an option to change the home-group password but it only works on the computer the home group was setup on.
Nov 05, 2013 | Microsoft Windows 7 Professional OEM...
canon PIXMA MG2120 all/in/one how can i set it up to be used by 3 different computers in my house
You can share a printer with all computers on your network pretty easily in Windows 7.
-First go to Control Panel and then Devices and printers
-Right click the printer in question and select Printer Properties
-Select the Sharing tab from this new window
-Click the tick box nest to Share this printer
-Click Apply in the bottom right and you are good to go
You can do the same in other operating systems, but the process/name of things may differ slightly.
Hope this helps.
Nov 01, 2012 | Canon PIXMA MG2120,INKJET PHOTO ALL IN ONE
file sharing between windows 2000 and XP
1) I believe that Windows XP is not setup for that by default,
you may need to install the old BETBUI service.
2) Also, if the 2000 machine has a login password installed,
it will NOT allow any other machine to browse it, without
logging in.
3) Password-less file sharing over NETBUI was available
on the consumer side of windows:
Windows 3.11 for Work groups
Windows 95, 98 and Millenium.
The professional versions of windows, built on NT
technology require a login:
Windows NT 4.0, Windows 2000, Windows XP,
and now Vista.
4) The best work around is to login to the 2000 machine when
it prompts you for a password, using your regular USER ID
and PASSWORD.
If the 2000 machine is not setup with a secure login,
just create a new account, ranking power user or higher.
5) Note that you only need to login over the network ONCE,
because windows XP can REMEMBER your password,
and login automatically the next time.
6) Make sure that the firewall (or A firewall) is not
blocking access to either machine, just disable the
firewalls for testing.
Similarly, if your LAN is behind a residential router, using
the router as a smart hub or switch, make sure that
the routers MAC address access blocking is disabled,
until you get everything setup and tested.
7) Finally if a PC is not visible in a work group, this does not
mean that it is not accessible. This is a Windows quirk.
You can try to access another computer by using the
default/administrative shares. These shares cannot be
disabled in XP, at least they will not stay disabled, as
they will restart during every reboot, whether you like it
or not.
This means that you can ALWAYS access all the drives
on another machine, whether you share them or not, unless
you take extreme measures in the local policies.
To access drive "E:" on a computer called "Henry" on a
machine in the same work-group,
open up windows explorer, and tyr the following into the
address line:
\\Henry\E$
This should access drive E:, after some delay, and possibly
a login prompt, even though drive is is NOT marked as
shared.
Down you just love windows ?!
Security by obscurity ?!
Microsoft is getting very good at hanging massive steel doors
on paper walls.
Hope this solves your problem, or gets around it.
Please rate my answers,
Martin
Jul 05, 2008 | Microsoft Windows 2000 for PC
114 people viewed this tip
David Payne
David Payne
