Tip & How-To about Computers & Internet
Useful Run Command Shortcuts
Hi All,
I know there are a lot of people who love using the run prompt or the
command prompt rather than using the mmc control...
So here are some quick tips that you can use ... Enjoy...
List big, but still i hope it is useful!!
* Accessibility Controls : access.cpl
* Add Hardware Wizard : hdwwiz.cpl
* Add/Remove Programs : appwiz.cpl
* Administrative Tools : control admintools
* Automatic Updates : wuaucpl.cpl
* Bluetooth Transfer Wizard : fsquirt
* Calculator : calc
* Certificate Manager : certmgr.msc
* Character Map : charmap
* Check Disk Utility : chkdsk
* Clipboard Viewer : clipbrd
* Command Prompt : cmd
* Component Services : dcomcnfg
* Computer Management : compmgmt.msc
* Date and Time Properties : timedate.cpl
* DDE Shares : ddeshare
* Device Manager : devmgmt.msc
* Direct X Control Panel (If Installed)* : directx.cpl
* Direct X Troubleshooter : dxdiag
* Disk Cleanup Utility : cleanmgr
* Disk Defragment : dfrg.msc
* Disk Management : diskmgmt.msc
* Disk Partition Manager : diskpart
* Display Properties : control desktop
* Display Properties : desk.cpl
* Display Properties (w/Appearance Tab Preselected) : control color
* Dr. Watson System Troubleshooting Utility : drwtsn32
* Driver Verifier Utility : verifier
* Event Viewer : eventvwr.msc
* File Signature Verification Tool : sigverif
* Findfast : findfast.cpl
* Folders Properties : control folders
* Fonts : control fonts
* Fonts Folder : fonts
* Free Cell Card Game : freecell
* Game Controllers : joy.cpl
* Group Policy Editor (XP Prof) : gpedit.msc
* Hearts Card Game : mshearts
* Iexpress Wizard : iexpress
* Indexing Service : ciadv.msc
* Internet Properties : inetcpl.cpl
* IP Configuration (Display Connection Configuration) : ipconfig
/all
* IP Configuration (Display DNS Cache Contents) : ipconfig
/displaydns
* IP Configuration (Delete DNS Cache Contents) : ipconfig /flushdns
* IP Configuration (Release All Connections) : ipconfig /release
* IP Configuration (Renew All Connections) : ipconfig /renew
* IP Configuration (Refreshes DHCP & Re-Registers DNS) : ipconfig
/registerdns
* IP Configuration (Display DHCP Class ID) : ipconfig /showclassid
* IP Configuration (Modifies DHCP Class ID) : ipconfig /setclassid
* Java Control Panel (If Installed) : jpicpl32.cpl
* Java Control Panel (If Installed) : javaws
* Keyboard Properties : control keyboard
* Local Security Settings : secpol.msc
* Local Users and Groups : lusrmgr.msc
* Logs You Out Of Windows : logoff
* Microsoft Chat : winchat
* Minesweeper Game : winmine
* Mouse Properties : control mouse
* Mouse Properties : main.cpl
* Network Connections : control netconnections
* Network Connections : ncpa.cpl
* Network Setup Wizard : netsetup.cpl
* Notepad : notepad
* Nview Desktop Manager (If Installed) : nvtuicpl.cpl
* Object Packager : packager
* ODBC Data Source Administrator : odbccp32.cpl
* On Screen Keyboard : osk
* Opens AC3 Filter (If Installed) : ac3filter.cpl
* Password Properties : password.cpl
* Performance Monitor : perfmon.msc
* Phone and Modem Options : telephon.cpl
* Power Configuration : powercfg.cpl
* Printers and Faxes : control printers
* Printers Folder : printers
* Private Character Editor : eudcedit
* Quicktime (If Installed) : QuickTime.cpl
* Regional Settings : intl.cpl
* Registry Editor : regedit
* Registry Editor : regedit32
* Remote Desktop : mstsc
* Removable Storage : ntmsmgr.msc
* Removable Storage Operator Requests : ntmsoprq.msc
* Resultant Set of Policy (XP Prof) : rsop.msc
* Scanners and Cameras : sticpl.cpl
* Scheduled Tasks : control schedtasks
* Security Center : wscui.cpl
* Services : services.msc
* Shared Folders : fsmgmt.msc
* Shuts Down Windows : shutdown
* Sounds and Audio : mmsys.cpl
* Spider Solitare Card Game : spider
* SQL Client Configuration : cliconfg
* System Configuration Editor : sysedit
* System Configuration Utility : msconfig
* System File Checker Utility (Scan Immediately) : sfc /scannow
* System File Checker Utility (Scan Once At Next Boot) : sfc
/scanonce
* System File Checker Utility (Scan On Every Boot) : sfc /scanboot
* System File Checker Utility (Return to Default Setting) : sfc
/revert
* System File Checker Utility (Purge File Cache) : sfc /purgecache
* System File Checker Utility (Set Cache Size to size x) : sfc
/cachesize=x
* System Properties : sysdm.cpl
* Task Manager : taskmgr
* Telnet Client : telnet
* User Account Management : nusrmgr.cpl
* Utility Manager : utilman
* Windows Firewall : firewall.cpl
* Windows Magnifier : magnify
* Windows Management Infrastructure : wmimgmt.msc
* Windows System Security Tool : syskey
* Windows Update Launches : wupdmgr
* Windows XP Tour Wizard : tourstart
* Wordpad : write
Computers & Internet Logo
%windir%\\system32\\devmgmt.msc i keep getting this message
This issue may occur when one or more of the .dll files that are used by the Microsoft Management Console (MMC) are missing or corrupted. These files include the following:
  • Msxml.dll
  • Msxml2.dll
  • Msxml3.dll
To resolve this issue, follow these steps:
  1. Click Start, click Run, type cmd, and then click OK.
  2. At the command prompt, type cd %windir%\system32, and then press ENTER.
    Note The %Windir% folder is the folder where you installed Microsoft Windows.
  3. Type the following commands. Press ENTER after each command.Regsvr32 Msxml.dllRegsvr32 Msxml2.dllRegsvr32 Msxml3.dll
  4. Type exit, and then press ENTER to close the Command Prompt window.
  5. Restart the computer.
Oct 16, 2011 | Microsoft Windows Vista Home Premium...
hello when i am opening device manager its not opening showing some error mmc console error
Hi Welcome to FixYa!
You could try different steps below on how to fix this problem.
1)You could download an automatic fix from Microsoft with this link: http://go.microsoft.com/?linkid=9657414
Then click Run in the File Download dialog box, and follow the steps in this wizard.
2) This issue may occur when one or more of the .dll files that are used by the Microsoft Management Console (MMC) are missing or corrupted. These files include the following:
  • Msxml.dll
  • Msxml2.dll
  • Msxml3.dll
  3. Type the following commands. Press ENTER after each command. Regsvr32 Msxml.dll Regsvr32 Msxml2.dll Regsvr32 Msxml3.dll
Hope this would be a big help!
Jun 22, 2011 | Computers & Internet
''mmc.exe Bad Image'' Windows 7
have you tried running sfc/scannow from a command prompt (run as administrator- when you type in "cmd" at the search button and right click on cmd.exe, and select run as administrator) Be sure to have your Windows7 CD in the drive when you run the check.
If after that it does not work, reinstall windows 7.
Dec 28, 2009 | Microsoft Windows Vista Ultimate Edition
i forgot my username password for a toshiba laptop running vista help please
Protocol questions - for more vivid mental image.
The logon screen, is it a 'classic logon' screen? IE do you get the option to enter a username and password or do you click an icon and then are prompted for a password?
Scenario 1
If not, you can use the logon 'panic button' = use Ctrl+Alt+Del trick {Ctrl+Alt+Del pressed twice} to make sure you get two fields to fill so that you log on as the Administrator. IE username = Administrator
password = {leave blank} Press enter and if you gain access, proceed to the Control panel or run | compmgmt.msc | local users and groups. From users, rightclick your account and then set password. Set the password, remember it, logoff and then logon with your credentials.
Scenario 2
Please take note this tip (if it works) is intended to regain a forgotten Vista Administrator password. It is not intended to illegally hack into a Vista system that’s not owned by you.
  1. Reboot the Windows Vista and boot up with Windows Vista installation DVD.
  2. While the Windows Vista installation interface pops up, click the Repair You Computer link at the bottom-left corner.
  3. Next, the System Recovery Options dialog box appears. There are few options but we want the Command Prompt option. Click on this option now.
  4. In the Vista Command Prompt, type mmc.exe and press the ENTER key to bring up the Microsoft Management Console.
  5. Click on the File menu, select Add / Remove Snap-in option, locate and select the Local Users and Groups on the left panel, and click Add button to add it to the right panel.
  6. Now, the Choose Target Machine dialog box pop up. Ignore this by clicking the Finish button
  7. Click OK button and return to the MMC window (the first window that showed when you entered mmc.exe). In the left panel, double-click Local Users and Group that was added in step 5. Click on User folder, locate and right-click the target Vista logon account whose password you need to set.
Guess you should know what to do now. Select the Set Password from the right-click menu to set a new password / reset old password.
Scenario 3
There is software out there than can do all the leg work for you like - NT & registry editor. Careful though. Can render your system useless if you don't know how to use them.
Dec 07, 2009 | Toshiba L305D-S5927 SATELLITE Notebook
MMC CANNOT CREATE A NODE MANAGER MAKE SURE THE FILE Mmcndmgr dll
I'm running windows 2000 and can't find that file.
Do a search for the file Mmcndmgr.dll and make a note of where it is on your system.
Then open a command prompt and use the following command to re-register it. replace the pathtofile with the location from the search.
regsvr32 c:\pathtofile\Mmcndmgr.dll
If you can't find the file then it may have been accidentally deleted.
Do a google on the file name and you should be able to find lots of information on it.
Hope this helps
Aug 15, 2009 | Microsoft Windows 2000 Professional Full...
167 people viewed this tip
David Payne
David Payne
