Tip & How-To about Computers & Internet
Make Windows XP smooth as Windows 7 part-2
Disable unnecessary services:
Some programs that launch at startup are invisible: they are services. There are dozens and some are useless. Both off, you can earn between 10 and 80 MB of RAM.
Click the Start button and then click Run.
In the Open field, type the command services.msc then confirm with Enter.
The services management console opens. To disable a service, double click it.
In the window that opens, scroll down the Startup Type list and select Disabled. The service will no longer be started with Windows.
Click the Stop button to stop it immediately.
Finally, click OK.
Here are some services you can disable: Remote Registry, Messenger, Help and Support, Support TCP / IP NetBIOS, Warning, Smart Card, Tracking Client Distributed Link, Secondary Logon, Network DDE, Windows Time, Performance Logs and Alerts, Automatic Updates Service Error Reporting ...
Stop System Restore:
System Restore, which is to take regular snapshots of your system to restore it if a problem is very resource-intensive and disk space. If you know what you do on your computer, you can disable it. Careful, it will clearly not be possible to create restore points manually or automatically, so no going back if something goes wrong.
Click the right mouse button on the My Computer icon on the desktop and choose the Properties command.
Open the System Restore tab.
Then check the box Turn off System Restore on all drives.
Click OK and Yes to confirm the deactivation.
Computers & Internet Logo
my exlporer emblem has a red line threw it and a round circle how do i get it off and explore back on.
Try running MALWAREBYTES freeware: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version. Run a FULL scan, delete ALL results, reboot. Use freeware CCLEANER to remove the junk and disable ALL unnecessary startup programs: http://www.filehippo.com/download_ccleaner/ Run the cleaner to free up disk and in the TOOLS section, STARTUP section, disable ALL unnecessary startup programs. UNINSTALL ALL unnecessary programs.
Mar 28, 2013 | Dell Vostro 1500 Notebook
cant print over the network on ricoh 3245c
assuming that u r using win xp pro sp2..n all the drivers are installed correctly..with proper print n file sharing turned on..
however,
open run->type 'SERVICES.MSC'->press ok/run->see if "Server; Computer Browser; Remote Registry; Secondary Logon; Workstation" service is set to Automatic n is Running..stop n disable "Windows Firewall" service..
hv a licensed and UPDATEDantivirus installed (i prefer avg/kaspersky, , without updation a fullversion antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeallthe unnecessary startup items from here..(if u can't find whatto remove, post me/us in ur comment with all the items listed in eachn every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disable thefollowing: a) 'Automatically Restart' right click onmy computer->properties->advanced->startupn recovery->(uncheck on the) Automatically Restart; b)'Error Reporting' right click onmy computer->properties->advanced->errorreporting->disable error reporting->(uncheck on the) 'but notifyme when critical error occur'..
to hv better supervision try contacting ur system admin/vendor....
Nov 07, 2009 | Office Equipment & Supplies
froze. very slow. very hot
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
Jul 12, 2009 | HP Pavilion dv6000z Notebook
103 people viewed this tip
David Payne
David Payne
