Tip & How-To about Computers & Internet
Make Windows XP smooth as Windows 7 part-1
If Windows XP works smoothly on the latest equipment, it can be trolling on an older machine or with economic components. For example Netbooks or nettops are not really swift and have limited disk space. If you start to open multiple applications simultaneously, you will soon experience slowdowns.
You can customize Windows to your material by removing or disabling everything that is unnecessary. You'll save responsiveness. Here are some of the tasks that you need to work on, just go through it:
Limit the Visual Effects:
Many visual effects adorn the Windows interface. You can disable to improve responsiveness. Below is how to do the same:
Click the right mouse button on the My Computer icon located on the Desktop and select the Properties command.
Open the Advanced tab.
Click the Settings button under Performance.
Then select the option Adjust for best performance. All visual effects are disabled.
Note that you can manually activate an effect that is important to you by ticking the box. Then press OK twice.
Rediscovering the classic theme:
The interface of Windows XP with all its colors and visual effects is consuming system resources. You can not keep clean and perfectly functional and interface.
Click the right mouse button on an empty space of desktop and choose the Properties command.
Scroll down and select Theme Windows Classic.
Click OK.
The theme of Windows XP Lite is immediately applied.
Computers & Internet Logo
Running Windows 7 and can't use my Photosuite 7 Platinum
Unfortunately Photosuite 7 is not compatible with Windows 7. It was supported for Windows 2000 and XP.
You can upgrade to the latest Roxio product, http://www.roxio.com/enu/products/allproducts.html?rTrack=m_pro_all . I think you need the Creator 2011. (Creator 2010 is also WIndows 7 compatible with the installation of a patch from Roxio.)
If you have Windows7 32-bit (click Start > Control Panel > System and Security > System for the details), you can try using the compatibility mode. Right click on the installer and select Properties. Then choose the Compatibility Tab. Select Run as Compatible with XP (I am not certain which SP option is best - I know the initial release is listed as SP1). Then right click again on the installer and choose Run as Administrator. Then check if the program is running in the compatibility mode. This may not work (it will not work with the 64-bit version at all).
If you have the 64-bit version of the OS or if the compatibility mode fails, you need a work-around. Your option is to run a computer with an older version of Windows. This can be a virtual, dual-boot, or true second machine. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install your Photosuite Platinum software in the XP mode (as you would if it were a stand-alone machine). It will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also your printer can not be installed on both the real and virtual machines at the same time.
I hope this helps.
May 03, 2011 | Roxio PhotoSuite 7 Platinum for PC
CS4 is not detecting WIA device or the Twain driver. I have down loaded the latest canon driver and installed it several times and the system will not connect the two programs. I am using Windows 7 (64bit) as my os.
The Canon software that you downloaded is for Win7 32-bit. Canon does not support this scanner on 64-bit OS versions. With Canon, I've found that the compatibility mode does not work.
A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or upgrade to them), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
Apr 14, 2011 | Canon CanoScan 8000F Flatbed Scanner
I have windows 7 I uses creata cars gold in my old computer but now it won't run in windows what do I need to do
You can either upgrade to the latest Broderbund greeting card software. (See this site for a list of all the Broderbund Design and Print products: http://www.broderbund.com/c-6-design-print.aspx . You may not be able to import old projects into the new software.)
Creata Card Gold 8 was for Windows XP and older OS versions. I suspect the compatibility mode will not work but you can try it. Right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This is more likely to work if you have Windows 7 32-bit.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them to print them. A printer can be installed to either the real or virtual machine at a given time. You will be asked to uninstall the printer if you try to install it in the virtual computer with it installed on the main computer.
I hope this helps.
Apr 04, 2011 | Broderbund American Greetings Creatacard...
My netbooks webcam doesn't work on things like ivideo chat or chatroulette and things like that. It simply says cannot connect to server. Why though? Is there something I can do to get it to work? I wasn't sure which Expert to pick so if it gets to the wrong one can you pass it on? Thanks :)
download your netbooks latest device drivers and supporting applications from the manufacturers web-site.that usually works, if you are using windows vista please change your operating system to xp or windows 7 which are much more stable and have less problems.
Feb 28, 2011 | Computers & Internet
Poor Resolution
think it has somethign to to with the compability,
example windows xp cant have directx 10 only 9 and lower even tho the graphics card is direct x10 compatible.
i dont know much about windows 98 but i am pretty sure thats the problem
May 28, 2009 | MSI MS-6340 Motherboard
100 people viewed this tip
David Payne
David Payne
