Tip & How-To about Computers & Internet
Bsnl broadband guide
If any of you are having a brand new BSNL Broadband connection, then you will be very excited that you will be able to utilize much more than in the normal connections like to browse as many websites, do as many downloads of audio and video.This even goes for the old users, but they may be experienced with this stuff, so it will be a great help for the new users.....
First of all one must give a check with the plan that is selected. So, the first point that has to be cleared is that it must be UNLIMITED.
While clearing the above point if you find out that the plan is something different, then either change the plan or always keep a check as to how much you are using. Otherwise, you will get a great shock when the bill arrives.
Make sure that you have a USAGE PORTAL ID as well as PASSWORD. This is provided by the officials. If you are not provided with it, then ask for the same. It is of great use for the BSNL users.
In case of any problems, contact the officials before getting any unauthorized help or trying any solutions by yourself. This is always recommended.
Register at all the official BSNL sites, especially the ones that provide help to your area and location. These will prove to be of help to you in times of trouble.
You always get all your correct information at the official BSNL portal. You cannot make a change that is made at their portal about any information about you regarding the internet usage or anything else.
These are some important points to be noted by the BSNL users.
I hope that these points prove to be of some help to the users.
Anyways, all your replies, comments and suggestions are very much appreciated.
Computers & Internet Logo
i have a router and switch d-line brand,how to bsnl broadband connection give to multi user
CONFIGURE UR ROUTER WITH BSNL. THEN CONNECT SWITCH TO LAN PORT OF THE ROUTER.CONNECT THE MULTIPLE PC TO IT
Dec 22, 2012 | Computers & Internet
i am unable to open many sites while using bsnl broadband..
BSNL have aways been known for its network problems
there are many websites actully lakhs of domains who are not authorised for use in bsnl domain.
SO. its better you try switching to some other broadband or 3g connections other than bsnl
Dec 27, 2010 | Computers & Internet
non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
sharing
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
Jun 28, 2008 | Intel Motherboard
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
164 people viewed this tip
David Payne
David Payne
