Tip & How-To about Cell Phones
Emmergency charge your ce phone
Imagine ur cell battery is very low, u r expecting an important call and u don't have a charger.
Nokia instrument comes with a reserve battery. To
activate,
key is "*3370#"
Ur cell will restart with this reserve and ur instrument
will show a 50% incerase in battery.
This reserve will get charged when u charge ur cellĀ
next
time.
*3370# Activate Enhanced Full Rate Codec (EFR)-Your phone
uses the best sound quality but talk time is reduced by approx.
5%
#3370# Deactivate Enhanced Full Rate Codec( EFR)
*#4720# Activate Half Rate Codec - Your phone uses a
lowerquality sound
but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
Cell Phones Logo
why we conect on low battery ,it charger not support ?
maybe your battery is weak
get a new one,or replace your charger
hope it helps..
Jan 18, 2013 | Nokia 5130 XpressMusic Red Unlocked Import...
i want o update my nokia n70 but where....?
Nokia instrument comes with a reserve battery. To activate, key is "*3370#"
Ur cell will restart with this reserve and ur instrument will show a 50% incerase in battery.
This reserve will get charged when u charge ur cell next time.
*3370# Activate Enhanced Full Rate Codec (EFR)-Your phone uses the best sound quality but talk time is reduced by approx. 5%
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound
2 *#0000# Displays your phones software version,
1st Line :S oftware Version,
2nd Line : Software Release Date,
3rd Line : Compression Type
3 *#9999# Phones software v ersion if *#0000# does not work
4 *#06# For checking the International Mobile Equipment Identity (IMEI Number)
5 #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
6 #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
7 #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
8 #pw+1234567890+4# SIM Card Lock Status.(use the "*" button to obtain the "p,w" and "+" symbols)
9 *#147# (vodafone) this lets you know who called you last *#1471# Last call (Only vodofone)
10 *#21# Allows you to check the number that "All Calls" are diverted To
11 *#2640# Displays security code in use
12 *#30# Lets you see the private number
13 *#43# Allows you to check the "Call Waiting" status of your phone.
14 *#61# Allows you to check the number that "On No Reply" calls are diverted to
15 *#62# Allows you to check the number that "Divert If Unrea chable(no service)" calls are diverted to
16 *#67# Allows you to check the number that "On Busy Calls" are diverted to
17 *#67705646#R emoves operator logo on 3310 & 3330
18 *#73# Reset phone timers and game scores
19 *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it
means you will get the best standby time possible
20 *#7760# Manufactures code
21 *#7780# Restore factory settings
22 *#8110# Software version for the nokia 8110
23 *#92702689# (to rember *#WAR0ANTY#)
Displays -
1.Serial Number,
2.Date Made
3.Purchase Date,
4.Date of last repair (0000 for no repairs),
5.Transfer User Data.
To exit this mode -you need to switch your phone off then on again
24 *#94870345123456789# Deactivate the PWM-Mem
25 **21*number# Turn on "All Calls" diverting to the phone number entered
26 **61*number# Turn on "No Reply" diverting to the phone number entered
27 **67*number# Turn on "On Busy" diverting to the phone number entered
Each command is prefixed with either one or two * or # characters as follows:
** Register and Activate
* Activate
## De-Register (and Deactivate)
# Deactivate
*# Check Status
© Call button
Once each command has been entered, if it is a network command (as opposed to a local handset command) it must be transmitted to the network by pressing the YES (receiver) key which acts as an enter key - this is represented here with the © character. Always enter numbers in full international format +CountryAreaNumber ( e.g. +447712345678).
Command Description Command String
Security
Change call barring code **03*OldCode*NewCode*NewCode#©
Change call barring code **03*330*OldCode*NewCode*NewCode#©
Change PIN code **04*OldPIN*NewPIN*NewPIN#©
Change PIN2 code **042*OldPIN2*NewPIN2*NewPIN2#©
Unlock PIN code (when PIN is entered wrong 3 times) **05*PUK*NewPIN*NewPIN#©
Unlock PIN2 code (when PIN2 is entered wrong 3 times) **052*PUK2*NewPIN2*NewPIN2#©
Display IMEI *#06#
Call Forwarding (Diversions)
De-register all call diversions ##002#©
Set all configured call diversions to number and activate **004*number#©
De-register all configured call diversions (no answer, not reachable, busy) ##004#©
Unconditionally divert all calls to number and activate **21*number#©
Activate unconditionally divert all calls *21#©
De-register unconditionally divert all calls ##21#©
Deactivate unconditionally divert all calls #21#©
Check status of unconditionally divert all calls *#21#©
Divert on no answer to number and activate **61*number#©
Activate divert on no answer *61#©
De-register divert on no answer ##61#©
Deactivate divert on no answer #61#©
Check status of divert on no answer *#61#©
Divert on not reachable to number and activate **62*number#©
Activate divert on not reachable *62#©
De-register divert on not reachable ##62#©
Deactivate divert on not reachable #62#©
Check status of divert on not reachable *#62#©
Divert on busy to number and activate /td> **67*number#©<
Activate divert on busy *67#©
De-register divert on busy ##67#©
Deactivate divert on busy #67#©
Check status of divert on busy *#67#©
Change number of seconds of ringing for the given service before diverting a call (such as on no answer). Seconds must be a value from 5 to 30. De-registering the same divert will also delete this change! **service*number**seconds#© (Service numbers, see below)
Call barring
Activate barr all outgoing calls (see Security to set code) **33*code#©
Deactivate barr all outgoing calls #33*code#©
Check status of barr all outgoing calls *#33#©
Activate barr all calls **330*code#©
Deactivate barr all calls #330*code#©
Check status of barr all calls /td> *#330*code#©<
Activate barr all outgoing international calls **331*code#©
Deactivate barr all outgoing international calls #331*code#©
Check status of barr all outgoing international calls *#331#©
Activate barr all outgoing international calls except to home country **332*code#©
Deactivate barr all outgoing international calls except to home country #332*code#©
Check status of barr all outgoing international calls except to home country *#332#©
Activate barr all outgoing calls **333*code#©
Deactivate barr all outgoing calls #333*code#©
Check status of barr all outgoing calls *#333#©
Activate barr all incoming calls **35*code#©
Deactivate barr all incoming calls #35*code#©
Check status of barr all incoming calls *#35#©
Activate barr all incoming calls when roaming **351*code#©
Deactivate barr all incoming calls when roaming #351*code#©
Check status of barr all incoming calls when roaming *#351#©
Activate barr all incoming calls **353*code#©
Jun 03, 2011 | Nokia N70 Cellular Phone
not getting battery full and easily low battery
change ur charger use original nokia charger. Change also ur battery 5630 uses bl-4ct which only have 860mah u can use a bl-5ct which has 1050mah better battery life. Or u can order a bl-4ct battery from dyno online shop which is modified for bznes purposes it has a 1500mah like E-series
Oct 10, 2010 | Nokia 5630 XpressMusic Smartphone
phone lock code
  • To check IMEI press *#06#.
  • To check the Software Version press *#170602112302#.
  • If Imagine the cell battery is very low, and an important call is expected what to do there is a a reserve battery in the absence of the charger then to activate the key and recharge the cell again is to press "*3370#".
  • #3370# To deactivate Enhanced Full Rate Codec( EFR).
  • *#4720# To activate Half Rate Codec.
  • *#0000# It displays the software version of the phone.
  • *#9999# To check the phones software version if *#0000# does not work.
  • #pw+1234567890+1# To check the Provider Lock Status. ( "*" sigh to obtain the "p,w" and "+" symbols).
  • #pw+1234567890+2# To check the Network Lock Status. ( "*" sigh to obtain the "p,w" and "+" symbols).
  • #pw+1234567890+3# To check the Country Lock Status. ( "*" sigh to obtain the "p,w" and "+" symbols).
  • #pw+1234567890+4# To check the SIM Card Lock Status.( "*" sigh to obtain the "p,w" and "+" symbols).
  • *#147# vodafone this lets you know who called you last time *#1471#.
  • *#21# Allows you to check the number that "All Calls" are diverted.
  • *#2640# It displays the security code.
  • #30# It lets you see the private number.
  • *#67705646# It removes operator logo on 3310 & 3330.
  • *#73# It reset the phone timers.
  • *#746025625# It displays the SIM Clock status.
  • *#7760# Manufactures code.
  • *#7780# Restore factory settings.
  • *#92702689# (to rember *#WAR0ANTY#).
  • Mar 19, 2008 | Cell Phones
    148 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
