Tip & How-To about Computers & Internet
How to connect your wireless computer to the wireless network ?
Connecting your wireless computer to the wireless network:
Make sure the wireless switch is turned on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected. You may also follow the navigation below according to your Operating System
WINDOWS XP: Start > Control Panel > Network and Internet Connections(Network connections) > Right Click Wireless Network Connection icon > Click on View Available Wireless Network
WINDOWS VISTA: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side click on Manage Network connections > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
WINDOWS 7: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side Click on Change Adapter Settings > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
MAC OSX: Select airport icon from desktop, turn on Airport, you will be able to view the available networks in range. Select your network name enter key and get connected.
You may also click on Apple logo > System preferences > Airport > select network name
You will be able to see the Network name (SSID) which you gave in the Router, try to connect to this it will ask for password type it and click on Connect. You will get connected wirelessly and able to go online.
Computers & Internet Logo
how to turn on the wireless card on Sony pcg11211L
If your computer will not connect to a wireless Internet signal, one of the first things to check is whether your computer's wireless switch is turned on.
Many laptop computers have a switch located on the exterior of the computer that controls its ability to connect to wireless networks.
This switch can be accidentally turned off, preventing users from connecting to the Internet.
Determine if your computer's wireless connectivity has been disabled by viewing the network icon in the lower toolbar on your computer's desktop.
When there is a disruption in your computer's Internet connection, the icon will have a red X through it. For further information, go to the computer's Network and Sharing Center where you can troubleshoot connectivity issues and view available wireless networks.
If the computer isn't recognizing any wireless connections (and you're sure that there are wireless signals in your area), the likely problem is that the wireless switch is turned off.
Locate the wireless switch on your computer.
It may be located on either side of the laptop or along the back or front.
If you aren't sure whether your computer has a wireless switch, check the user guide that came with the unit.
Determine whether the switch is currently in the "On" or "Off" position.
The switch will be clearly labeled.
Push the switch in the direction of the "On" position to ensure that it is turned on.
If the switch was already turned on, see if there is a keyboard combination that will activate your laptop's wireless capability.
The key combination for your laptop will depend on your computer's manufacturer, but will generally involve a combination of the Function, Control or Alt and the F1 to F12 keys.
Check your user manual for your computer's key combination.
Troubleshoot problems finding wireless networks
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
Mar 23, 2014 | Sony Computers & Internet
I don't know how to turn on the wireless capability on myself?
What type of computer Desktop or Laptop & Make ???...
Aug 13, 2013 | Computers & Internet
how do I turn on my wireless connection
Jun 13, 2013 | Computers & Internet
i do not know my wireless pc
b> If your computer will not connect to a wireless Internet signal, one of the first things to check is whether your computer's wireless switch is turned on. Many laptop computers have a switch located on the exterior of the computer that controls its ability to connect to wireless networks. This switch can be accidentally turned off, preventing users from connecting to the Internet.
Determine if your computer's wireless connectivity has been disabled by viewing the network icon in the lower toolbar on your computer's desktop. When there is a disruption in your computer's Internet connection, the icon will have a red X through it. For further information, go to the computer's Network and Sharing Center where you can troubleshoot connectivity issues and view available wireless networks. If the computer isn't recognizing any wireless connections (and you're sure that there are wireless signals in your area), the likely problem is that the wireless switch is turned off. Locate the wireless switch on your computer. It may be located on either side of the laptop or along the back or front. If you aren't sure whether your computer has a wireless switch, check the user guide that came with the unit. Determine whether the switch is currently in the "On" or "Off" position. The switch will be clearly labeled. Push the switch in the direction of the "On" position to ensure that it is turned on. If the switch was already turned on, see if there is a keyboard combination that will activate your laptop's wireless capability. The key combination for your laptop will depend on your computer's manufacturer, but will generally involve a combination of the Function, Control or Alt and the F1 to F12 keys. Check your user manual for your computer's key combination. Troubleshoot problems finding wireless networks
Mar 14, 2013 | Toshiba NB505N500BL 1 GB Hard Drive
I just turned my computer on and it is not recognizing my network. I get an error message "check to make sure the wireless switch on your computer is on" What wireless swithch?
There's a little switch, usually along one side, that slides back and forth. It will completely disable wireless. It is there for using your laptop on an airplane, or if you just want to make sure you are not connecting to wireless network. Check closely all around the laptop and you should find it.
Jul 25, 2009 | Toshiba Satellite A75-S1253 Notebook
943 people viewed this tip
David Payne
David Payne
