Tip & How-To about Computers & Internet
Fix Windows 7 Error ?Windows is Not Genuine? Error code 0×80070005
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B).
Method A: Disable the Plug and Play Policy 1. Determine the source of the policy . To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to “Not Defined.” Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy: 1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template, Query status, Enumerate dependents, Interrogate, User-defined control, Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)
(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)
(A;;CCLCSWLOCRRC;;;IU)
(A;;CCLCSWLOCRRC;;;SU)
S:(AU;FA;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;WD)
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to “SU” (SDDL_SERVICE – Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO’s in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
1. On the computer that is out of tolerance, start Registry Editor.
2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions…
3. If the NETWORK SERVICE is not present, click Add…
4. In Enter the object names to select type Network Service and then click Check Names and OK.
5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
6. Restart the computer.
7. After the restart, the system may require activation. Complete the activation.
Computers & Internet Logo
How do I fix 'error 10060' in my Outlook mail account?
How to Fix the Socket Error 10060 Home > Outlook > How to Fix the Socket Error 10060
PC Support Hotline: 1-844-377-4107 DOWNLOAD
Certified safe, virus free download. Error Tools Editor's Choice. Error Causes
The cause of this error code is hard to narrow down typically because there are many causes that can trigger the socket error code 10060. Some of the most common causes of this error code are:
  • Issues in email settings
  • Authentication settings
  • Firewall settings
  • Malware
Though this is not a critical error code but it is advisable to fix it immediately without any delays.
This error can hamper your communication via email and slow down your work productivity especially if you use Outlook for communication across the organization. Further Information and Manual Repair
Here are some of the many methods to fix and resolve this error code. To help you resolve this issue, we have selected and listed down the best, quick and easy do it yourself methods. Try them and repair Socket error code 10060 all by yourself without any professional assistance.
Method 1 - Check the Names of POP3 and SMTP Servers
To begin with, first check the names of the POP3 and SMTP servers to ensure that they are correct. Then check the outgoing SMTP port. Contact your email provider to determine the correct settings.
Sometimes email providers change this value more than any other in their individual settings. Get it verified. Change the settings if needed.
Method 2 - Outgoing SMTP Server Requires Authentication
Sometimes the error code may occur due to authentication issues. If this is the reason then, don't worry it is easy to fix. Simply go to the settings options and check the box 'My server requires authentication'.
Once you check the box, try sending the email again. This is most likely to resolve the socket error 10060 on your PC.
Method 3 - Disable Firewall
Your Firewall security may sometimes be the reason for socket error 10060 too. Therefore if after trying method 1 and 2, the error still persists, then it is advisable to disable firewall.
Once you disable it, try sending an email using your Outlook account. If it works, the error is resolved.
Method 4 - Scan for Malware
There is a possibility that the Socket error 10060 is popping on your PC due to malware infection. If so, then it is advisable to download Total System Care.
This is a highly functional and a user-friendly PC fixer deployed with a powerful antivirus and several other scanners. Run it on your PC to scan for malware. It detects and removes all types of malware including Trojans, viruses, adware, spyware and more in seconds.
Dec 27, 2017 | Computers & Internet
I have genuine windows 7 but computer says that it is not genuine
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B). Method A: Disable the Plug and Play Policy
1. Determine the source of the policy. To do this, follow these steps:
a. Edit the Group Policy that is identified in Step 1 and change the setting to "Not Defined." Or, follow the section below to add the required permissions for the Network Service account.
Query template
Query status
Interrogate
Read permissions
sc sdshow plugplay
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to "SU" (SDDL_SERVICE - Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
Note: If there are no GPO's in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
  2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions...
  3. If the NETWORK SERVICE is not present, click Add...
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 13, 2011 | Microsoft Windows 7 Ultimate 32 & 64 BIT
how to enable registry editing
Method 1 - Using Group Policy Editor If you are using an edition of Windows Vista (Windows Vista Business, Enterprise and Ultimate editions) which includes the Group Policy Editor, follow these steps:
  • Click Start, type gpedit.msc in the Search box, and press ENTER
  • Go to the following branch:
User Configuration | Administrative Templates | System
  • Double-click Prevent access to registry editing tools
  • Set it as Not Configured
Important: If it's already set to Not Configured, set it to Enabled and click Apply. Then repeat the steps and revert the setting back to Not Configured. This removes the registry based policy if set already.
Method 2 This method should work in all editions of Windows Vista.
  • Download reg_enable.vbs attached at the end of this article, and save it to Desktop
  • Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  • Switch to your Desktop directory by typing the following command, and then pressing ENTER:
cd /d %userprofile%\desktop
  • Then, type the following command and press ENTER
wscript.exe reg_enable.vbs
  • Type EXIT to close the Command Prompt window.
If everything worked fine, the DisableRegistryTools policy should have been removed by now. See if you're able to launch Regedit.exe now.
Dec 11, 2008 | Microsoft Windows XP Professional
1,000 people viewed this tip
David Payne
David Payne
