Tip & How-To about Audio Players & Recorders
Bluray Firmware and where to get the latest downloads
Bluray player firmware
Here are a list of bluray players and the link to help you get the latest firmwares. I will be adding several players and for some you may need to click on the manufactures link as not all have a direct link for every player.
AMEX
BD-P1-None out but you can see the home page for Amex here
Blucobra
EZ3000-no firmware and it seems the homepage is gone.
BUSH
BD-0-no firmware. Player was sold in England and has been discountinued
Curtis Mathes
CMMBX130
cmmbx72
Daewoo
DBP-1000-None available
Daewoo-2000-none available
Denon
DBP-2010CI
DBP-1610
DVD-3800BDCI
S-5BD
DBP-4010UDCI
Funai
NB500MGXA
NB500MG1F
Insignia
BRDVD
2BRDVD
BRDVD3
BDLIVE01
BRDVD3CA
BRHTIB
NS-WBRDVD
SAMSUNG
HT-BD1250T
HT-BD72000
BD-P1500
BD-P1590
SHARP
BD-HP20
BD-HP21
BD-HP50
I will be updating this all the time and list when it was updated. Please check back and send me a message in the comments section if you have anything to add. Thanks for your help!!!
ver 0.3.2 posted on 7/08/2010-Added several more players and updated links.
I have a friend who has a PIONEER Bluray Player BDP LX52.Despite having updated it to the latest firmware(3.71)it is not playing the RED(Morgan Freeman,Bruce Willis)Bluray.Sometimes he gets the menu and playback starts(trailers)then "cannot play this disc"appears on the screen.Do you have any idea what causes this? Regards, Viraj
The firmware update needs to be done again.
Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
IMPORTANT: Prior to following the steps below, go to the Drivers & Software section of the Pioneer eSupport Web site to check for available firmware updates. If a firmware update is available, it will be posted there with a list of improvements over the original or any previous firmware version. Some disc playback issues may be resolved by ensuring the BD player has the most current firmware installed.
  1. Ensure the Easy Setup procedure has been completed on the BD player. NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
  2. Ensure the inserted disc is compatible with the BD player. NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
  3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step. NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
  4. Use a soft cloth to clean the disc.
  5. Examine the disc for any cracks or scratches that might be interfering with playback.
  6. Wipe the top of the disc tray using a soft dry cloth before placing the disc on the tray. Attempt to play the disc again.
  7. Attempt to play another disc. Remove the disc from the BD player.
  8. Turn off the BD player.
  9. Unplug the power cord of the BD player from the electrical outlet.
  10. Let the player remain without power for 1 minute.
  11. Plug the power cord back into the electrical outlet.
  12. Turn on the BD player.
  13. Insert the disc into the BD player.
  14. Attempt to play the disc.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required
Apr 08, 2011 | Pioneer BDPLX52 BluRay Player
need to update firmware
This is the latest firmware out for this bluray player on the link below
http://www.samsung.com/us/support/owners/product/BD-P3600A
Feb 27, 2011 | Samsung BD-P3600 Blu-Ray Player
I can't play some discs that are listed i have been told that i have to upgrade. I don't know how
In most cases, the issue might be with the Java content on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service.
I hope the above information helpful. If you need any further clarification, please let me know.
Thanks for understanding.
Feb 22, 2011 | Sony BDP-S300 Blu-Ray Disc Player
My Sony BDP-S370/BX37 does not play all the Bluray discs I have. For instance it will not play Tim Burton's Alice in Wonderland but will play Disney's Sleeping Beauty and Coraline. What do I need to do?
In most cases, the issue might be with the Java contents on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6237&mdl=BDPS370
If the issue persists after installing the firmware update, it would have been with the disc. Check the disc with another player; try different discs with same player.
Jan 20, 2011 | Sony BDPS370 BluRay Player
Downloaded latest firmware update but will not play breaking bad season 1. Loads upto menu screen and then freezes.
latest 2,3 on my bluray,,bdp 1400, samsung,, still showing menus at chapters on several discs,,inc avatar..this will stop me buying new discs, till they sort out upgrades,,may be a 6 months wait,, but worthit to avoid this ****,hassle and hair loss.
May 20, 2010 | Samsung BD-P1400 Blu-Ray Player
355 people viewed this tip
 Grubhead
Grubhead
