Tip & How-To about Computers & Internet
How To Change Password Of Users In Windows XP
On Internet, I found so many people are confused about how to change the passwords of users in Windows XP even though it is a easy job. As far as we know, changing logon password of our Windows regularly is a good habit to help keep our PC secure, I just researched and found out the below ways to change the password of users in Windows XP. You can use either one to achieve your goal.
Follow the simplest ways you thought to change your Windows XP logon password:
If you know any other interesting way, please let me know through comments.
Using Control Panel
Difficulty: Easy
Time Required: Changing your Windows XP logon password usually takes less than a few minutes
Here’s How:
go to Start –> Control Panel –> User Accounts
Tip: You can also open control panel by Start –> Run –> control. This will open Control Panel.
Select the user for which you want to change the password and select Change my password.
Note: you must need appropriate privileges to change the password of another user.
Using Ctrl+Alt+Delete
Difficulty: The easiest one in my opinion
Time Required: It just takes me one minute
Here’s How:
If your press Ctrl+Alt+Del when you are logged onto your Windows XP machine, it will show you the classic security options.
Select change password and change the password of the logged on user.
Note: If the security options does not appear. Task manager shows up instead of the security options. Just go to Start –> Control Panel –> User Accounts –> Change the way Users Log on or off.
Uncheck Use the Welcome Screen. Log off and logon again. Now pressing Ctrl+Alt+Del will show the security options window.
Using Command Prompt
Difficulty: medium
Time Required: It may takes a few minutes
Here’s How:
go to Run –> cmd.
Command prompt will open. Use the following commands to change the password:
net user username password /domain
Replace username with the original username and password with the new password you want to assign to that user. /domain is optional. If you are in a domain environment, specify the domain name otherwise, if you’re using a local user, leave /domain. If I want to change the password of user Sanix to 12345. I will issue the following command at command prompt:
net user Sanix 12345
It will change the password of the user Sanix to 12345.
Note: if you’re not logged on as an administrator, you will get the following error:
“System error 5 has occurred. Access is denied”
Using Control userpasswords2
Difficulty: Easy
Time Required: It may takes less than a few minutes
Here’s How:
go to Start –> Run –> control userpasswords2
This will open the classic user accounts management window. Select any user and select reset password.
Using Computer Management Console
Difficulty: Easy
Here’s How:
right click My Computer –> Manage –> Local Users And Groups –> Users
Right click the username for which you want to change the password and select Reset Password.
If you compare the ways hereinabove carefully .You’ll find that the premise of using above ways to change your PC users password is you must logon the system with a user who has the appropriate privileges to change the password of another user. But if you forget any user password including administrator, what can you do?
Tips:
Windows Password Recovery 6.0 is your best choice, it is an easy-to-use tool designed for resetting local administrator and user passwords on any Windows system. If you have forgotten your password , or are locked out, or you do not have access to the password of the system. No need to call a technician, no need to re-install anything, and you certainly don’t need to reformat, just download this effective utility .
Free Download Link : Windows Password Recovery 6.0
Quick Start: Get a quick start by following the step-to-step tutorial here…
Computers & Internet Logo
how do i change my password and get a new password
If you lost windows password, you could enter into safe mode (F8 when booting up) to retrieve windows password while you forgot user account password, but when you forgot admin password, there is no way to change it, you need to use a software application to recover administrator password. A week ago, I forgot my Windows admin password. Last, I used Windows Password Seeker to recover my Windows password successfully. It's worth a try.
http://www.passwordseeker.com
Aug 09, 2011 | Computers & Internet
How to recover a lost Windows xp password
Well received your useful tips .. it was very useful . kindly do not stop at any cause because sharing knowledge will equal to gain the knowledge. so, I also recommend another easily and safely software claim to recover forgotten windows password -- Windows Password Recovery 6.0 you can download the product form : http://www.recoverlostpassword.com/products/windowspasswordrecoery.html I wish you all the best for your regardless service. with love
May 05, 2010 | Computers & Internet
Can't sign on to computer. Won't accept my password. It is as if it is locked.
You can use a Computer Password Recovery to get the admin password. It is a live cd easy to use.
When you load it in graphical mode select the windows installition and then select the user you want to reset password.
(make sure you boot from cd/dvd or usb first)
Dec 26, 2010 | ASUS Eee 4G Notebook
FORGOT WINDOWS USER PASSWORD
As far as I know, Windows Password Recovery Tool 3.0 is safe and easy to use. An .ISO file included in windows passwords Recovery.
Dec 18, 2010 | IBM ThinkPad T20 2647 Notebook
How do i unlock admin code for windows xp bought computer at radio shack they lost code
http://users.skynet.be/sky77609/opre/cd060213.zip
This should reset the password, but you have to install this to a CD-ROM and insert it to your laptop, but need to change the order of your driver boot-up. If you have any problem e-mail me at poundsblake@gmail.com Hope this helps!?
Please rate solution - Thanks
May 15, 2010 | Computers & Internet
264 people viewed this tip
David Payne
David Payne
