Tip & How-To about Cosco Juvenile Scenera Convertible Car Seat - Daisy Daze
How to get almost ANY stain out of carpet! WITH ONLY WATER
This is a super simple way to get just about any kind of stain out of carpet, I used it on a grape jelly stain that was about a day old, and it worked.
STEP 1:
Fill a bowl with at least 5 times the amount of whatever caused the stain.
STEP 2. (optional)
put a little bit of laundry soap in the water, swish it around.
STEP 3.
Dump the water onto the stain, DON'T RUB IT IN!!
STEP 4.
Soak up the water with a towel, paper towels, whatevers handy, blot it, but don't rub it in--the rubbing or scrubbing you usually associate with getting out stains is what smears the stain cause into the carpet, or fabric fibers. It's important to not let the spill get "enmeshed" into the fibers, the water sort of will lift the spill off of the area.
STEP 5
Repeat steps 3 and 4 until spill is gone.
Cosco Juvenile Scenera Convertible Car Seat - Daisy Daze Logo
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
HOW TO SPOT CLEAN A CARPET I have a "furry family" of a dog and 2 cats who I love dearly. Unfortunately, my carpet has suffered from several "accidents" and "upset tummies". It is a challenge to find an effective cleaner that cleans the stain, reduces the odor in the carpet, and is reasonably priced. In the past, I have tried commercial products that were both expensive and ineffective. I have also used vinegar mixed with water and, although it was effective, it did not achieve the results that I would have liked. So one day, I decided to mix a little scented fabric softener in with the vinegar and water and VOILA what a difference! It removed the stain and left the carpet soft and smelling fresh. It has become my preferred method of dealing with pet stains on the carpet. If you decide to give this a try, be sure to test this solution on an inconspicuous place on your carpet to be sure it does not discolor or lighten it. So far, I have had only good results from its use. To Spot Clean a small area: Fill an empty clean spray bottle with equal parts of water and vinegar. Then add a capful of scented fabric softener to the bottle. Shake it up for 30 seconds. Spray the stained area Let it sit for 2 minutes and then spray a little more on it. Rub the stain with a dry cloth until it disappears. The vinegar odor will fade as it dries and helps to remove the foul smell Let it dry and you will notice a nice fresh smell and your carpet will be soft. Once you vacuum, you will have a hard time telling where the stain was. I have actually used the mixture above in my Bissell Carpet Cleaning machine with good results. It is much less expensive than commercial carpet cleaning solutions. Be sure to read your machine manual or contact the manufacturer to make sure it does not affect its operation. So far my machine is tolerating it well. This is a personal tip that I just wanted to share with others. I hope you find it useful.
Apr 12, 2011 | Vacuums
What can I use to remove a stain of SOYSAUCE in a carpet?
Carpet
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Nov 21, 2014 | Heating & Cooling
1,043 people viewed this tip
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
