Tip & How-To about Televison & Video
DLP TVS
I get many calls every day from customers that the lamp light is flashing and they want to charge the bulb alone. I also get many calls everyday from customers that have bought that new lamp from a web site and installed it themselves and the unit still does not work why? A word of warning any malfunction with the color wheel or the ballast will cause the lamp light to flash, and what is even worst allot of the units you can not change the color wheel by itself it is inside the light engine a costly repair
Televison & Video Logo
Mitsubishi WD-52327 TV won't consistently turn on, new lamp
the problem is in the power supply circuit
capacitor may be or so the click mean theres cap are leakink or get dry that why is so long to power on.
hope that give you a idea.
May 05, 2010 | Televison & Video
Panasonic PT-56LCZ70 no picture or sound
My name is Jonathan and I am an employee at the Panasonic Customer Call Center. Based on the symptoms you've described, I'd recommend contacting the Panasonic Customer Call Center at 1-800-211-7262 for assistance. We are here to help customers that have purchased (or are considering purchasing) our products and would like to assist you with resolving the symptoms described here. Our hours of operation are:
Mon - Fri, 9 AM - 9 PM EST
Sat - Sun, 10 AM - 7 PM EST
Dec 11, 2008 | Panasonic PT-56LCZ70 56" HDTV
akai 46in rear projection
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy.
Hope ya fix it!
Jan 06, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
207 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
