Tip & How-To about Computers & Internet
How to bypass your password on windows xp.
There are 2 ways that i know.1-Start computer and hold down f8 while it is starting up.There should be an administration log in icon leave the password area blank and then press enter.You will get into your computer and then you can reset the password or disable it.2-You can use the same type of methed as step1 but instead of holding down f8 jus tap ctrl.. alt delete 2 times during welcome window and then admin will come up and do the same as step1
Computers & Internet Logo
have a netbook but no passwords when turned on windows asks for password
you can try to see if they have set an administrator password, start the computer in safe mode (Hold down F8 when booting) and when it boots click on the administrator logon icon, if there is no password (as there sometimes isn't) you can log on and go to the user control in control panel and create a new user. then re-start and logon using the new account you created.
Mar 06, 2012 | Sony Vaio P VGN-P530H Netbook
I have a Dell latitude e4310 laptop my 10 year old has somehow changed the password and locked my computer. Can you please help
If you haven't set a password for the Administrator account you could try to log in as an Administrator then change your password back. First you need to change how users log on.
1. Click Start
2. Click Settings
3. Click Control Panel
4. Click User Accounts
5. Click Change the way users log on or off
6. Deselect Use the Welcome screen
7. Click Apply options
Exit Control Panel. Then Restart computer, hold F8 when rebooting and choose SafeMode when prompted.
When Log on Prompt appears type in Administrator as user and leave password blank ( this is the Windows default password)
This will let you boot into Windows where you can go back to Control Panel, User Accounts and change your account password.
Then just reboot normally and enter new password.
Hope this helps. Thanks for using FixYa.
Sep 17, 2011 | Computers & Internet
I WANT TO LOG IN TOSHIBA TECRA 550CDT BUT I HAVE FORGOTTEN MY PASSWORD
start your computer in "safe mode" :
  1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
    Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, click the arrow next to the Lock button eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c.png, and then click Restart.
  2. Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
  3. On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode option you want, and then press ENTER. For more information about options, see Advanced startup options (including safe mode).
  4. Log on to your computer with a user account that has administrator rights.
Depending on you operating system i.e. windows XP, 7 etc. you may not have a "lock" button described in STEP 1, just restart while holding down F8, once you are in safe mode you can go in to Administrator or any other account and reset your password
Aug 08, 2011 | Toshiba Tecra 550CDT Notebook
how to unlock computer passwords
I don't know weather you're doing this for legal purposses, at least I assume you are and as a result I will also assume you have direct access to the computer in question. An easy way to get access to a computer without knowing the users password would be to boot it in safe mode and just use the Administrator account.
1. Shut down the computer
2. Press F8 when windows screen appears
3. From the list, go to the option Microsoft Windows using your keyboard
4. Instead of pressing the Enter key, press the F8 key again to display the Safe Mode boot screen.
5. Choose Safe Mode from the list and press the Enter key.
6. You will be taken to the log in screen that will display the Administrator account icon among your other current account's.
From here you can log into the Admin account without having to enter a password and can fully use the computer.
Mar 01, 2011 | Computers & Internet
forgot password
Here are 2 options to change lost administrator password without learning it. Hope they can work for you!
Option 1: If you can log on your laptop with an administrator account, you can change the password following the steps:
1. Right-click Computer to select Manage.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3. Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Note: you can also go to Local Users and Groups screen by clicking Start button and inputting lusrmgr.msc into the Search box.
Netplwiz.
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type \Administrator\ (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from \Control Panel - User Accounts\.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
If you have another administrator account,you can use this account to remove the administrator password.
You can also use the default Administrator account that is built into Windows XP.
First you need to boot the system into Safe Mode.
1.Restart your system.
2.When you see the blue Dell globe or screen, press the ( F8 ) key about 3 times a second.
3.You should get the Windows startup menu. Use the (Up or Down) arrow keys to highlight (SafeMode)
4.Press (Enter) on (Safe Mode), then press (Enter) on (Windows XP).
5.The system should boot to Safe Mode.
Once you are at the Account Log on Screen, click on the icon
for the user account with administrator rights, or click on the icon
for the administrators account.
Note: For Home the Administrator account isn't normally shown & in Safe Mode you have to press Ctrl+Alt+Delete keys twice to show.
For PRO you can do this in normal mode
When the system has booted to the desktop, use the following steps to change the accounts password.
1.Click Start, Control Panel, Administrative Tools.
2.Click Computer Management.
3.Double click Local Users and Groups, double click the folder Users.
4.Right click on the account name that is locked out, and click on Set Password.
5.You may get a warning message about changing the password, simply click proceed.
6.Leave the New Password box blank, also leave the Confirm Password box blank.
7.Click OK, and OK again.
8.Then close all Windows, reboot the system and try to log in
There is another easy and safe way for you to recover/delete the unknown windows password, it is widespread accepted by its 100% recovery rate and All passwords reset instantly.
Source(s):
Related Tutorial about how to reset windows password by using windows password recovery tool:
http://www.lost-password.net/products/passwordrecovery.html
Mar 20, 2010 | ASUS Eee PC 900 Notebook
134 people viewed this tip
David Payne
David Payne
