Tip & How-To about Sony Network Walkman NW-E005 MP3 Player
No Data/Format error on Sony Network Walkman
Sony Network Walkman does not support adding / removing of files, or formatting if it is not done from SonicStage, their software.
If music is added of removed from windows explorer or other software, the player gives an error message 'No data' or something similar.
To fix the problem, download and install SonicStage from Sony support website.
Select your model and click continue, then scroll down, select your operating system in the select box to the bottom of the page and select the software you want to download...
After installing, connect the player to your computer and select 'format' from the menu (This will remove all data from the player, so you might want to make a backup).
Now transfer your music files to the player using sonicstage.
Good Luck
Sony Network Walkman NW-E005 MP3 Player Logo
i want to add video songs via sonic stage but they are not added..
The NWZ-S616F Walkman Player is not transferring the music using the SonicStage Software. Sony old Walkman player was using the SonicStage Software for transferring the files. You can use Windows Media Player 11 or higher, Media Manager for Walkman, Content Transfer Software or Windows Explorer for transferring the files to the Player.
Click here and select the operating System to download the Software for transferring the files.
Thanks for using FixYa.
May 06, 2011 | Sony Walkman NWZ-S616F MP3 Player
how do i format my sony mp3player walkman
You have to work from Sonicstage.
Follow these steps:
Install Sonicstage (probably you've already done that)
If you don't transfer them using sonicstage, the player data will get corrupt and tell you there is no data.
May 17, 2008 | Sony Network Walkman NW-E005 MP3 Player
Help?
The player doesn't accept adding or removing of music, or formatting, when it is not done from SonicStage, the software that sony offers with it.
The software is to be downloaded here. When you've installed the software, format the player from the menu. Then transfer your music with this program.
Please rate the solution
Good luck
Mar 18, 2008 | Sony Network Walkman NW-E005 MP3 Player
database deleted
The player doesn't accept removing of music, or formatting, when it is not done from SonicStage, the software that sony offers with it.
That'll do the trick.
Please rate the solution if it helped
Mar 16, 2008 | Sony Network Walkman NW-E005 MP3 Player
troubleshooting
The software is to be downloaded here. When you've installed the software, format the player from the men. Then transfer your music with this program.
Aug 25, 2007 | Sony Network Walkman NW-E005 MP3 Player
24,044 people viewed this tip
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
