Tip & How-To about Sharp AR-M350U Copier
F2-02 error code on Sharp AR-M350/450 and 355/455 Copiers
The F2-02 code will often be the result of a defective or after market toner cartridge. Try replacing the cartridge and power cycling the copier before placing an expensive service call.
Sharp AR-M350U Copier Logo
printing blank page even in test mode. hplaserjet 1200
Checking the toner cartridge
Image formation defects are many times the result of problems in the toner cartridge. If there is any doubt, always replace the toner cartridge before troubleshooting image defects.
Use the following checklist to make sure that the toner cartridge is still operable.
" Make sure that the toner cartridge is seated properly.
" Inspect the toner cartridge for toner level.
" Check the expiration date stamped on the toner cartridge box.
" Check the toner cartridge to see if it has been disassembled or refilled.
" Inspect the toner cartridge to see if toner is leaking through worn seals.
" Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting
and image defects.
" Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Note A toner cartridge weighs approximately 863 grams (30.5 oz) when it is full, approximately 766 grams (27.0 oz) when it first fades, and approximately 742 grams (26.2 oz) when it is empty.
To redistribute toner in the cartridge
Before installing a new cartridge or when toner begins to run low, redistribute the toner by rotating the cartridge back and forth five or six times.
Jul 27, 2011 | HP LaserJet 1200 Printer
my copier sharp5316 has error code of f2 pls help me on this.
That is normall a defective developer unit chip, you may have to replace the chip on the developer unit or the developer unit itself.
Aug 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
lDell 3100cn awer printer won't recognize new toner
Have you removed the plastic protection strip from the bottom of the toner?
Nov 14, 2008 | Dell 3100cn Laser Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
2,875 people viewed this tip
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
