Tip & How-To about Sharp AR-M355N Copier
Replacing Toner on a Sharp AR-M350/450 or 355/455 Copier
It's very easy to mistake where and how to replace toner on this unit. It's often assumed that Area 1 is where the toner is. This is actually the Developer Housing. If the developer unit is pulled completely from the copier, its weight will often surprise the user and they drop it on the floor, or worse, dump out the developer believing that it's waste toner. The correct area for the toner cartridge is Area 2. Area 1 is used only to lower the developer unit and unlock it from the toner cartridge, so that the cartridge, itself, can then be removed freely from the copier. If the developer unit is mistakenly pulled and dropped or dumped, a service call will usually be required to recharge the developer unit.
Sharp AR-M355N Copier Logo
xerox workcentre m24 replace toner even if the toner is new
There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
Aug 30, 2014 | Xerox Office Equipment & Supplies
2300dl toner problems
Unfortunalely printers and there drivers estimate toner life buy counting the amount of dots draws on the pages. Say a cartridge is rated for 3000000 dots when new, the printer will know after printing 1500000 dots that the cartridge is about half full. If you replace a cartridge the printer will assume it's new as the ID tag will be different from the last cartridge. There really isn't any way of modifying or specifying the age of a cartridge. You will just have to keep using it until you start seeing drop outs on the page, then you will know it is almost empty. Shaking it a few times will usualy help stretch the life of a cartridge.
Jul 04, 2008 | Konica Minolta magicolor 2300DL Laser...
RESET DRUM UNIT COUNTER
please described easy words
Mar 06, 2013 | Panasonic DP-C322 Copier
I am looking to purchase a AR-M455N, are there known problems?
Thats a very good copier which is fast and can be networked. Problems are those with other copiers so no need to worry.
Nov 10, 2009 | Sharp AR-M455N Copier
smearing yellow toner on copies
Yellow is usually the least used color and it is usually near the fusing unit getting the heat. It seems to "dust" more than the others.I have found that yellow toner seems to build up under or around the yellow drum unit to the point that a passing page will contact the actual buildup near the yellow drum area. Take a visual inspection around the yellow drum area. Make sure you charge coronas are clean. Hope this helps.
May 07, 2009 | Canon Office Equipment & Supplies
2,490 people viewed this tip
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
