Tip & How-To about Vacuums
Vacumm maintainence
Vacuums should be carefully clened and the filters checked or changed as well as the belts no less than once every three months. unplug vacuum when working on them they are fairly east to work on. the most common promlem are clogged filters or debris not allowing the roller to turn freely which then puts a load on the belts and motor. you will have to learn how to take your brush roller out to do your own maintainence at home. iots not that hard are usuallyonly takes a phillips screwdriver or maybe a stardrive bit you can but at the hardware store. good luck.
Vacuums Logo
My Shark vacuum is making a weird noise how to fix it
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator Lift-Away Vacuum is making a loud noise while it's on then there's definitely a clog somewhere. Here' s a few places you should check prior to plugging in the vacuum and turning it on.
The first place to check would be the brush roll and belt. If you notice visible debris, like strands of hairs, or long carpet fibers this could be catching on the brush roll and causing it not to turn fully. Be sure to clear this debris from the brush roll and manually spin the brush roll a few times after you do so to help unearth and any other clogs. This may be the reason for the noise and its crucial that this part of your vacuum is clog free.
Another part of your vacuum to check would be your hose. Detach the hose and stretch it out as much as you can to see if any debris or clumps of dust are stuck inside. Using a broom handle can help if you see a clog, but it won't come out after you've stretched out the hose.
Another big factor would be a dirty filter in your vacuum. Most manufacturers recommend you change your filter on average every 3-6 months. However, it is recommended to change your filter even earlier depending on usage and allergy care. The cleaner your filters the less debris will get stuck in your vacuum, causing less clogs and overall less odd noises while vacuuming.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=nv355
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 23, 2014 | Shark Navigator Lift-Away Professional...
bissell proheat 2x troubleshooting
Hi, it's Allie from Crucial Vacuum!
There are several things that may cause this to happen in your Bissell ProHeat 2x, like the brush assembly or the belts.
First, make sure the cleaner is reclined, or the brushes will not turn. If your unit is reclined and the brushes still do not run, check if there is anything tangled in your unit's brushes or if the brushes are damaged. Clear the brushes of any hair strands or tangled debris for their optimum performance. We recommend for these brushes to be cleaned and checked monthly and replaced once a year.
Next, unplug your unit and check both of your units belts. It is recommended for belts to be changed every 3 to 6 months, depending on the use of your unit. Belts can be stretched out and loose, causing the brushes not to spin properly.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
Alejandra (Allie) Sepulveda-Rivera
Aug 15, 2014 | Bissell 7901-1 ProHeat Scotchgard Upright...
brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Jul 19, 2009 | Hoover U6616-900 WindTunnel Bagless...
NOT PICKING UP OR SUCTIONING AS WELL AS IT DID WHEN I FIRST PURCHASED IT.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=556324
Generic problem for all Vacuums
Posted by PEACH34711 on Apr 29, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It would be my suggestion to change the belt and to clean off the brushroll. A suggested belt change for a flat belt is every 4 to 6 months depending on the use of the vacuum, and if you have a geared belt (with teeth) then the belt change is once a year or so depending on use, check the hoses to make sure they are clear and clean the filter or change the bag, this should take care of the problem. On you next request please specify the brand name & model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 29, 2008 | Vacuums
215 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
