Tip & How-To about Pioneer VSX-816-K/S Receiver
How to make a Pioneer vsx-816k/s last longer
I really don't recommend this product to anyone, or any newer pioneer products for that matter (except the elite line). This model has the "hybrid" design, which is a very flawed design. At first the speakers will start cutting in and out, and then some of them wont work at all, and then the receiver will flash "overload" and the receiver will go into a permanent protection, all because the receiver cant handle the resistance of the speakers(doesn't matter what speaker it is). Once in protect mode, press ENTER+ ADVANCED SURROUND and it will tell you what the problem is causing it to stay in protect mode. In order to keep this from happening, use external amps. Pioneer wants around 500 dollars to fix it if its out of warranty, it will cost at least 50 to fix it yourself, in most cases it will cost 150 to fix it yourself (most cases all 3 power modules will go out, or as pioneer calls them, power packs). If you have an older vsx model (50s-80s) then it is usually worth fixing. If your having problems with pioneer vsx 3600, 3700s, 3800, or 3900s, send me an email at Joshadk@embarqmail.com and i will help you the best i can
Pioneer VSX-816-K/S Receiver Logo
Pioneer Elite 1140 HD not working : reds light blinks 4 times
Four blinks of standby light to Plasma TVs, denotes a voltage output failure from its main power regulator board. Check this link for more. http://electronicshelponline.blogspot.com/ Pull up older posts there. Blinking codes to most Plasma TV brands will be similar. Check them. Pioneer brand is also there.
Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Does this TV overheat and fail if installed in a cabinet with no cooling system? Can the boards burn out?
ANY TV WILL FAIL IF PROPER COOLING IS NOT PRESENT. A GOOD RULE OF THUMB IS AT LEAST 2 INCHES OF CLEARANCE AROUND THE ENTIRE SET. ANYTHING LESS, I WOULD RECOMMEND ADDITIONAL COOLING SOLUTIONS.
Aug 13, 2010 | Pioneer Elite PRO-1540HD 60 in. Plasma...
pioneer deh-p3950mp unit plays disc but won't eject or respond to any other commands except volume. any ideas anyone
Just follow this link for manual
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players/DEH-P4950MP?tab=D
Mar 01, 2009 | Pioneer DEH-P2900MP CD Receiver...
Pioneer amplifier
Below is a list of all of the older model Pioneer amplifiers; your's isn't in it. I don't think you have a real Pioneer product but rather a knock off amp. If you locate the model number below you can follow this link to locate a manual for it: http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/ch.Amplifiers.Archived?vgnextfmt=Archived
Jun 04, 2008 | Car Audio & Video
2,067 people viewed this tip
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
