Tip & How-To about Computers & Internet
What is Packed.Mystic!gen5 virus and how to remove it
For remove Packed.Mystic!gen5 virus,please clean/delete all Packed.Mystic!gen5 infected files and Delete/Modify any values Packed.Mystic!gen5 added to the registry as following:
SUMMARYTECHNICAL DETAILSREMOVAL.
This virus is first detected: April 28, 2010
Updated: April 28, 2010 8:11:01 AM
Type: TrojanSystems
Affected: Windows 2000, Windows 95, Windows 98, Windows Me, Windows NT, Windows Server 2003, Windows Vista, Windows XP
Packed.Mystic!gen5 is a heuristic detection for files that may have been obfuscated or encrypted in order to conceal themselves from antivirus software. It is used to detect threats associated with the trojan.FakeAV family.For more information, please see the following resource:
trojan.FakeAVAntivirus. This virus /Worm/Torjan self protect for the following Dates. Initial Rapid Release version April 28, 2010 revision 003. Latest Rapid Release version April 28, 2010 revision 003Initial Daily Certified version April 28, 2010 revision 021 Latest Daily Certified version April 28, 2010 revision 021Initial Weekly Certified release date April 28, 2010A trojan horse that opens a back door on the compromised computer that modifies the home page and desktop settings on a compromised computer.,ADware can also slow your Internet connection by using bandwidth to retrieve advertisements. In addition, adware can increase the instability of your system because many adware applications are not programmed well.it can automatically plays, displays, or downloads advertisements to a computer after the adware software is installed.steals information such as bank accounts, usernames, passwords and credit card details from your computer and sends it to the attacker. here for a more detailed description of Rapid Release and Daily Certified virus definitions.This virus/maleware/sapm/Worm threat report:SUMMARY detect level of this level SUMMARY detect level of this level
Level: LowNumber of Infections: 0 – 49
For successful remove Packed.Mystic!gen5 virus,you may also need do as following:
1. Temporarily Disable System Restore .
2. Update the virus definitions. Reboot computer in SafeMode;
3. Delete the IE temp files,some Packed.Mystic!gen5 temp file exisit there.
Read more information at flowing links:
PC solutions
Computers & Internet Logo
how to clean woaurud.scr????? helllp
WOAURUD.EXE remove instruction 1. Temporarily Disable System Restore, Reboot computer in SafeMode; 2. Locate WOAURUD.EXE virus files and uninstall WOAURUD.EXE files program. Follow the screen step-by-step screen instructions to complete uninstallation of WOAURUD.EXE. 3. Delete/Modify any values added to the registry related with WOAURUD.EXE,Exit registry editor and restart the computer; 4.Clean/delete all WOAURUD.EXEinfected file(s):WOAURUD.EXE and related,or rename WOAURUD.EXE virus files; 5.Please delete all your IE temp files with WOAURUD.EXE manually,run a whole scan with antivirus program ;
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 31, 2010 | Computers & Internet
is recycler a virus.
Yes it is a virus
1st: Go to Tools>Folder Options>View>unckeck this items below:
1>display the contets of system folders
2>hide extensions for known file types
3>hide protected operating system files(Recomended)
2nd:check all other options in VIEW
3rd:APPLY>OK.
4th:Download unlocker 1.87 ,install it after that enter any drive (C:\,D:\,........) and delete the recycler folder >then a error message will appar and shows that " can not delete RECYCLER:access is denied." it's in use.>click "OK">after that the "unlocker 1.87" will appears automatically and will give options "noaction","delete","rename","move" at down-left corner and there you can select " delete" optinon by scrolling down and after that you can success fully delete the virus,RECYCLER,from that drive.:D
continue this proccess for all drives where you can see RYCLER folder
Jan 14, 2010 | Computers & Internet
vietcong game wont open,Backdoor Ranky keeps popping up.I know its not a virus,I am using win Xp home.Running ruddy awfull norton internet security 2008
It seems you have been infected by a trojan. This virus infects all versions of WIndows OS: It is considered a Low Risk Virus, but it needs to be removed immediately.
Backdoor.Ranky.Z allows unauthorized access on the infected pc by opeing a backdoor port.
Technical Name: Backdoor.Ranky.Z
Lets Remove the Virus:
  1. Disable your system Restore; this is to keep the virus from restoring itself to do this:
  • Right click on my computer
  • click on properties
  • select system restore tab
  • check "turn off system restore" uncheck "to turn on"
  • click Apply
  • click Yes when dialog box tell s you this will erase all restore points.
  • Press OK
2. Make sure your virus definitions are up to date.
3. Reboot your system in Safe Mode
4. Run a full/deep system scan & delete all infected files.
5. Delete/Modify any values added to theRegistry
how to edit registry
Delete this entry :
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \"Advanced DHTML Enable" = "[PATH OF TROJAN EXECUTABLE]"
6. Exit registry editor and restart your PC.
7. Run a Full scan to make sure it is really gone.
Hope this helps (rate high if this helps)... Good luck! ^_^
Sep 17, 2009 | TOPICS Entertainment Vietcong 2
windows cannot find file csrcs.exe
File csrcs.exe is located in the folder C:\Windows\System32.
Program has no file description. The file is not a Windows system file. The application is loaded during the Windows boot process.
The program is not visible. It is an unknown file in the Windows folder. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to monitor applications, hide itself, record inputs, manipulate other programs. Therefore the technical security rating is 86% dangerous.
It simply means, "It is very dangerous"
Try these steps to remove it.
Click on START-RUN,
type regedit (it will open the registry editor)
Press Ctrl+F
type "csrcs" (without quotes) and click on Search It'll show you some results, where you'll find "csrcs.exe" delete it immediately.
Again do the same search you may see "explorer.exe csrcs.exe" , right click then modify and remove the csrcs.exe part (leave the explorer.exe as it is)
Hurray !!! you have removed csrcs.exe
Restart your system and see it for yourself
Don't forget to give feedback
Sep 05, 2009 | Computers & Internet
i have win32 virus in my pc...
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
Disable System Restore (Windows Me/XP).
Remove all the entries that the risk added to the hosts file.
Run a full system scan and delete all the files detected.
Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
How to disable or enable Windows Me System Restore
How to turn off or turn on Windows XP System Restore
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To remove all the entries that the risk added to the hosts file
Navigate to the following location:
Windows 95/98/Me:
%Windir%
Windows NT/2000/XP:
%Windir%\System32\drivers\etc
Notes:
The location of the hosts file may vary and some computers may not have this file. There may also be multiple copies of this file in different locations. If the file is not located in these folders, search your disk drives for the hosts file, and then complete the following steps for each instance found.
%Windir% is a variable that refers to the Windows installation folder. By default, this is C:\Windows (Windows 95/98/Me/XP) or C:\Winnt (Windows NT/2000).
Double-click the hosts file.
If necessary, deselect the "Always use this program to open this program" check box.
Scroll through the list of programs and double-click Notepad.
When the file opens, delete all the entries added by the risk. (See the Technical Details section for a complete list of entries.)
Close Notepad and save your changes when prompted.
3. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
Running LiveUpdate, which is the easiest way to obtain virus definitions: These virus definitions are posted to the LiveUpdate servers once each week (usually on Wednesdays), unless there is a major virus outbreak. To determine whether definitions for this threat are available by LiveUpdate, refer to Virus Definitions (LiveUpdate).
Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them. To determine whether definitions for this threat are available by the Intelligent Updater, refer to Virus Definitions (Intelligent Updater).
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
4. To scan for and delete the infected files
Start your Symantec antivirus program and make sure that it is configured to scan all the files.
For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
Run a full system scan.
If any files are detected, click Delete.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
5. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
Click Start > Run.
Type regedit
Click OK.
Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
Navigate to and delete the subkey:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\RpcRemotes
Navigate to the subkey:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup
In the right pane, delete the value:
"Ph4nt0m" = "Ph4nt0m"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\wuauserv
In the right pane, reset the value to the original value if applicable:
"Start"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess
"Start"
Exit the Registry Editor.
also u can use the link for free download of virus removal tool
http://www.bitdefender.com/site/Download/browseFreeRemovalTool/
Jan 22, 2008 | Computers & Internet
224 people viewed this tip
David Payne
David Payne
