Tip & How-To about Dryers
Gas dryer quick fixes for no heat/clothes not drying problems
Ok, it seems that everyone is having problems with their gas clothes dryer not drying clothes these days. Here's a few things to check that most people can do on their own. Keep in mind, that if you start taking the unit apart, you need to unplug the unit first. We don't want anyone getting zapped!
1) Obvious things first. If you have a propane gas dryer, make sure you are not out of gas! Go to the tank, lift the lid, look at the % gauge. If it's pointing at 5% or less, you may be empty or about to run out of gas. Order a gas delivery.
2) Another obvious tip. Check your lint filter. It may be so clogged that your dryer can't breathe. Clean it. Using a flashlight, look down into with the filter opening and see if there is a lot of lint still inside. If so, try using a small vacuum attachment and clean out lint. This applies to both gas and electric dryers.
3) Most gas dryers have either a small access panel in the front or at the very least, a peep hole. Open the panel or pop out the plastic peep hole cover so you can view the igniter. Turn on the dryer and watch for orange glow at the burner. If it does not glow, it will not light the gas burner. You may have a broken igniter and will need to replace it or have a new one installed. If you do it yourself, be sure to unplug the dryer and do not touch the very fragile ceramic piece of the igniter. You can confirm it is broken by locating the broken piece below where it is attached or noting it is missing a piece of ceramic on the igniter.
4) This tip applies to both gas and electric models. Another thing you can do is check for blockage in your vent. Unplug the dryer, and pull the unit out as far as you can to get access to the back of the unit. Be careful not to step on or kink the gasline. Pull the venting off the back of the dryer. There is usually a squeeze clamp holding it on. Clean out lint in dryer and from within the vent tube. Some cheap venting are made of expandable plastic or aluminum and can get squished to the point they restrict air flow. Make sure your vent is not collapsed and doesn't get squished when you push the unit back. Once you have cleaned and reassembled it, plug it in, turn on the dryer and watch for ignition. If it lights, go outside to the vent cap and check for lint there and make sure your vent flap opens with the hot air flowing out. Clean and adjust as necessary. If you have a long vent tube like I have on mine, then you should clean it out annually. I use a wind-up toilet snake and crank it around knocking lint loose from the walls of the vent. I can always tell when it needs to be cleaned again, when clothes no longer get dried in the first cycle. If you are unsure of, or unable to perform this task, then you'll need to hire a repairman.
Anyway, these are just the easy, quick fixes that most homeowners can perform on their own. If none of these solve the problem, you will need to troubleshoot further or hire a repairman. Hope this helps.
Dryers Logo
dryer not heating very hot. need to run two cycles to dry
Dryer is not drying properly, In order to resolve try following things.
  • Check the exhaust hood outside the house, does it open and close freely, Clean the lint filter and exhaust duct.
  • Do not overload, 1 wash load = 1 dryer load. Sort heavy items from lightweight items.
  • Large, bulky items like blankets or comforters may require repositioning to ensure even drying.
  • Check the washer to be sure it is draining properly to extract water from the load.
  • Clothes load is too small to tumble properly. Add a few towels.
I hope this will solve your problem.
Good luck and have a nice day.
Jul 04, 2010 | Frigidaire GLGQ332A Gas Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
water standing in dryer
If it is a vented dryer, then check the vent hose for blockage, or kink in the hose,. also, make sure the filter is clean.
Please rate my sol;ution.
Thanks.
Aug 06, 2009 | Dryers
dryer wont dry clothes
Vents can fool you sometimes they seem to be ok but still cause problems. Try running with vent unhooked from machine one time and see if it works ok.
Check for leaks air leaks around the door or anywhere else.
Jun 10, 2009 | Whirlpool LER4634J Electric Dryer
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
461 people viewed this tip
Top Dryers Experts
