Tip & How-To about Microsoft Xbox 360 Console
How to set up your xbox 360 without causing overheat
Take everything out your new xbox 360 packaging. there should be:
1)a console (obvioiusly)
2) a cable that connects your 360 to a power block
3) a power block that connects your xbox to the wall
4) a cable that connects your xbox to the tv
5) a small rectangular box that connects your cable into the scart port on your tv.
lets begin
take the cable and connect it to the power block and move the power block to the side
take the scart plug (small rectangular box) and connect the yellow white and red wires into the approprite slots (these are marked out on your scart plug) and move to the side
pace your console down 90 deg. on its side in your desired position.
WARNING WARNING WARNING WARNING WARNING WARNING WA
do NOT place your xbox 360 standing up as this can cause red ring of death syndrome and other known xbox killers due to overheating i am on my second 360 as i never followed my own advise.if you keep your console standing straight it can cause vibrations which knock your cooling sinc out of place. it can also scratch your games more easily and ring them making them UNPLAYABLE. now place all cables you set aside and connect them into appropriate slots on the back of the console. and connect them into wall socket and tv.
thanks for reading.now wheres the free cake i was promised.
Microsoft Xbox 360 Console Logo
my xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
what do i do if a red ring comes on the xbox
This problem depends on how many red lights there are. The problems can be from a corrupt hard drive, to an overheated console. In this solution, I will mention all problems, and solutions.
1 Red Ring means hardware failure in your Xbox console. It can also mean hard drive corruption. There are multiple solutions to this problem. Turn off your console and unplug every single cord, cable, and memory device on your console. Wait about twenty seconds, and plug everything back in into it's origanal spot, and make sure everything is connected correctly. If the problem still occurs, try unplugging the console's hard drive, then turn on your Xbox 360. If your console then works after this, it could mean your hard drive is corrupt, or broken. Make sure to also disconnect all other memory units out of your console, such as a memory card. If the problem continues, contact Microsoft Support at the following link.
http://www.xbox.com/support/contact
2 Red Rings means that your Xbox 360 console is overheating. Overheating is a common problem with Xbox 360 consoles. Turn off your Xbox console. Make sure it is in a roomy spot, and not near a heated spot. Also make sure it is not on top of a towel, or anyplace cluttered. As seen here,
natesprague6_4.jpg NEVER cool off a Xbox 360 in a refridgerator, or freezer. This may cause further problems to your console.
3 Red Rings means there is a hardware problem, or something wrong with your power supply. To solve this, make sure the color on your power supply is always orange, when your Xbox 360 is off. Also make sure the color is always GREEN when it is on. If it is RED when you turn your Xbox on, try unplugging every cord, cable, and memory device on your console, and plugging it back in about 20 seconds after, and make sure all plugs are connected securely into it's socket. If this does not resolve your issue, contact Microsoft support at the link at the following link,
4 Red Rings indicates that there is no audio/video plugs detected from your AV plug. This is a simple problem to fix. Make sure all plugs are connected firmly into the correct color sockets on your TV. The following colors are the ones that need to be plugged in a Flat Screen TV,
2 Red, 1 Green, 1 Blue, 1 White. As seen here,
natesprague6_5.jpg Although, on a small, old TV, you usually only need to connect the yellow, and white cables. Make sure if you're using an old TV that does not support HD, switch the AV cable to 'TV', if it is switched to 'HD'. If this does not work, you may have to buy a new AV cable.
I hope this helped you, and the Fixya community! Contact me if you're still having trouble!
Jul 02, 2011 | Microsoft Xbox 360 Console
three red lights
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
Unfortunately, a large number of folks know all to well from their own experience. Fortunately for those who have not opened their console for any reason Microsoft has extended the warranty of ANY console experiencing the 3 red lights failure for a full three years from the manufacture or purchase date.
Jan 08, 2008 | Microsoft Xbox 360 Console
xbox 360
Ok so here is your problem, you are getting the 3 red lights due to a system/ hardware malfunction, possibly due to the spacers located next to the Xclamp on the inside of your board. If you dont want to open your console, try this.
1. Unplug your Audio/Video Cables from the xbox as well as you Hardrive.
2.Keep your Power cable in.
3.Wrap your broken 360 in 2 towels, so that it is completely covered and no air can escape.
4. Keep like that for 20 minutes.
5. The Xbox should be very hot at the end of the 20 minutes
6. Remove the towels and let cool for 15 minutes.
7. Plug everything back on and power up.
=) should work, but only temporary.
If you want a perma fix just message me.
Hope this helps,
Christian D.
Jan 06, 2008 | Microsoft Xbox 360 Console
xbox 360
Hi, I hope something from below is useful to you...
Sections 1, 2, 3, and 4 are flashing red
- The AV cable cannot be detected
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful in any way, please rate! Thanks
Nov 24, 2007 | Microsoft Xbox 360 Console
590 people viewed this tip
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
