Tip & How-To about Lands Phones
How to send apps to your sciphone through your computer.
1. you will need a computer that has BLUE TOOTH
2. turn on your bluetooth and then SEARCH for a new device, when the device shows your computer click bond
3. then the bluetooth asks you for a CODE make sure you enter a code you can remember. then click OK
4. it automatically asked you computer to for the code enter the SAME code you had already entered for you phone then click ok
5. click yes on your phone when it asks you do you want to save the blue tooth info on your phone.
6. download the apps you want on your phone to your computer from the internet.
7. Click on the blue tooth icon on your computer, click the name of your phone when you see it and then it shows you to send file or custom, click on send file.
8. it ask you to select the file you want to send then click on the app you had downloaded before, if you don't see it on your computer search for it and then click send. it sends it to your recieved folder of your phone, open the folder and then click on the app and click on install and follow the step and you can always find it from the java app it self on your phone,
Lands Phones Logo
can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
when i tryto use bluetooth this messages appear "no local bluetooth devise was detect"
If your laptop blue-tooth switch is enabled, then you need a second device with blue-tooth like a phone or laptop in range. Make sure the devices' blue-tooth adapter is switched on.
Dec 13, 2010 | Lenovo 3000 Y410 Notebook
My Bluetooth set is plugged in but will not show up to add
Try to put your headset in pairing mode first. Press and hold the K1 button for some 8 seconds, until the indicator led is rapidly flashing alternately in red and blue. Then, make your PC's bluetooth application search for new devices. Your headset should appear. Select it make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done just once. After any 2 devices are paired, they should connect to each other just by being next to each other (provided their bluetooth radios are turned on, of course). Othewise, a simple press on the button should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 28, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
how do i set up bluetooth on my pc?
Hello!
First you need to turn on the wireless switch. Next, if you want to do pairing (sync with another device), you should turn the blue-tooth on the other device.
Then right click on the blue-tooth icon on the system tray (near desktop clock), then select "Add a blue-tooth device", now check the box "my device is ready to be found", then click "next".
Your laptop will find the other device (sometimes you need to try a couple of times). After that it may ask you for a password. You can type e.g "1" on your device. You'll also be asked same on the other device, use same password.
Now pairing has been done & you can send files to & from other device.
Sometimes you need to right-click on the blue-tooth icon & click receive a file.
please send us your vote & feedback. Bye
Feb 21, 2010 | Toshiba Satellite L25-S1193 notebook
I need help connecting my blue tooth to my phone device
Hello
If you are referring to connecting your pone to your blue tooth device(dongle pluged into your computer?), you activate the blue tooth on your phone, plug the device into youre computer and right click on the blue tooth icon in the bottom right corner which will appear after a few seconds.
Click on ad device, your device will then search for other blue tooth devices.
Your phone must then appear.
double click on your phone, then you will be asked to enter a password. Enter anything and then next.
Your phone should now ask for a password then enter it.
Now the devices are paired.
Now just use the send via Blue Tooth function.
Hope you find this usefull.
Sep 13, 2009 | Plantronics - Bluetooth Headset Plus Base...
242 people viewed this tip
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
