Continued
What can go wrong
The most common problems occur in the microwave generating portion of the
system, though the controller can be blown by a lightning strike or other power
surge. Bad interlock switches probably account for the majority of microwave
oven problems. Also, since the touchpad is exposed, there is a chance that it
can get wet or damaged. If wet, a week or so of non-use may cure keys that
don't work. If damaged, it will probably need to be replaced - this is
straightforward if the part can be obtained, usually direct from the
manufacturer. Unfortunately, it is an expensive part ($20-50 typical).
The interlock switches, being electromechanical can fail to complete the
primary circuit on an oven which appears to operate normally with no blown
fuses but no heat as well. Faulty interlocks or a misaligned door may result
in the fuse blowing as described above due to the incorrect sequencing of the
door interlock switches. Failed interlocks are considered to be the most
common problems with microwave ovens, perhaps as high as 75% of all failures
No adjustments should ever be required for a microwave oven and there are no screws to turn so don't look for any!
General system problems The following problems are likely power or controller related and not in the microwave generator unless due to a blown fuse or bad/intermittent connections:
Note: when working on controller related problems, unplug the connection to the microwave generator (HV transformer primary) from the power relay or triac - it is often a separate connector. This will prevent any possible accidental generation of microwave energy as well as eliminating the high voltage (but not the AC line) shock hazard during servicing.
If this does not help, there is likely a problem with the controller circuitry or its power and you will have to get inside the oven.
Uninvited guests Some cockroaches (or other lower life forms) may have taken up residence on the controller circuit board. It is warm, cozy, safe, and from their point of view makes an ideal habitat. If you got the microwave oven from a flea market, garage sale, the curb, a relative, or friend, or if your kitchen isn't the cleanest in the world, such visitors are quite possible. Creatures with six or more legs (well, some two legged varieties as well) are not known for their skills in the areas of housekeeping and personal hygiene. Clean the circuit board and connectors thoroughly with water and then isopropyl alcohol. Dry completely. Inspect the circuit traces for corrosion or other damage. If there are any actual breaks, these will have be be jumpered with fine wire and then soldered. Hopefully, no electronic components were affected though there is always a slight possibility of other problems.
Totally dead oven First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn! If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
If the main fuse is upstream of the controller, then any short circuit in the microwave generator will also disable the controller and display. If this is the case, then putting in a new fuse will enable the touchpad/display to function but may blow again as soon as a cook cycle is initiated if there is an actual fault in the microwave circuits.
Therefore, try a new fuse. If this blows immediately, there may be a short very near the line cord, in the controller, or a defective triac (if your oven uses a triac). Or, even a shorted oven lamp - remove and inspect the light bulb and socket.
If it does not blow, initiate a cook cycle (with a cup of water inside). If the oven now works, the fuse may simply have been tired of living. This is common.
If the fuse still blows immediately, confirm that the controller is operational by unplugging the microwave generator, power relay, and/or triac from the controller. If a new fuse does not now blow when a cook cycle is initiated - and it appears to operate normally - then one of the components in the microwave generator is defective (shorted).
Some models have a thermal fuse as well and this may have failed for no reason or a cooling fan may not be working and the oven overheated (in which case it probably would have died while you were cooking something for an important guest - assuming you would use a microwave oven for such a thing!).
Other possible causes: bad controller power supply or bad controller chip.
Totally dead oven after repair On some microwave ovens, there is at least one cabinet screw that is slightly longer than all the others. This engages a safety interlock which prevents the oven from receiving power if the correct screw is missing or in the wrong hole. Check the length of all the screws and locate the interlock switch behind one of the screw holes. I don't know how common this practice is but have heard of it on some Sharp models.
Dead controller The most common way that the controller circuitry can be harmed is by a power surge such as from a lightning strike. Hopefully, only components on the primary side of the power transformer will be affected.
- Totally dead oven.
- No response to any buttons on touchpad
- Oven runs when door is still open.
- Oven starts on its own as soon as door is closed.
- Oven works but display is blank.
- Whacked out controller or incorrect operation.
- Erratic behavior.
- Some keys on the touchpad do not function or perform the wrong action.
- Microwave oven does not respond to START button.
- Check the primary of the power transformer - if it is open, there may be a
fuse/thermal fuse underits outer insulation. If not, the transformer will
need to be replaced. There is a good chance that the surge didn't propagate
beyond the transformer and thus the rest of the controlled should be
unaffected.
- In some cases, circuit board traces may have been vaporized (but repair may
still be possible by simply jumpering across the crater). Some of these
thin traces may be there specifically to act as fuses - and there may even
be spares to use for just this situation!
- Assuming that the main fuse and power transformer primary checks out, then
check the power supply for the controller next.
- As always, also check for bad solder connections.
Did you find this Tip Helpful?
Can you Help with these Microwave Ovens problems?
Kenmore 80412 / 80414 / 80419 Microwave Oven
kenmore model 721.6365330
trying to put glass back into... Answer This...
Kenmore over the range...
1000 watts - model 721.63653300... Answer This...
Kenmore 80412
Kenmore 80412
I just purchased a Kenmore... Answer This...
Sponsored Links
Repair Service
Find Microwave Oven Repairman Near You:
Find Parts
