Troubleshooting Guide
- Problem: Totally dead oven.
Possible causes:
- No power to outlet (blown fuse or tripped breaker or GFCI).
- Blown main fuse - likely due to other problems.
- Open thermal protector or thermal fuse.
- Defective controller or its power supply.
- Clock needs to be set before other functions will operate (some models).
- Problem: Totally dead oven after repair.
Possible causes:
- Cabinet screws replaced in incorrect location (safety interlock not engaged).
- Any number of screwups. :)
- Problem: No response to any buttons on touchpad.
Possible causes:
- Door is not closed (some models).
- You waited to long (open and close door to wake it up).
- Controller is confused (pull plug for a minute or two to reset).
- Defective interlock switches.
- Faulty controller or its power supply.
- Touchpad or controller board contaminated by overenthusiastic cleaning.
- Defective/damaged touchpad.
- Problem: Oven runs when door is still open.
Possible causes:
- Damaged interlock assembly.
- Cooling fans (only) running due to bad sensor or still warm.
- Problem: Oven starts on its own as soon as door is closed.
Possible causes:
- Defective triac or relay.
- Problem: Oven works but display is blank.
Possible causes:
- Broken display panel.
- Oven needs to be reset (pull plug for a minute or two to reset).
- Problem: Whacked out controller or incorrect operation.
Possible causes:
- Previous or multipart cook cycle not complete.
- Defective sensor (particulalry covection/mirowave combos).
- Problem: Erratic behavior.
Possible causes:
- Bad connections in controller or microwave generator.
- Faulty relay - primary (or HV side, much less commonly used).
- Bad contacts/connections on mechanical timers. Intermittent fuse.
- Power surge at start of cook cycle confusing controller.
- Microwave (RF) leakage into electronics bay.
- Problem: Some keys on the touchpad do not function or perform the wrong
action.
Possible causes:
- Faulty controller.
- Problem: Microwave oven does not respond to START button.
Possible causes:
- Defective START button.
- Faulty interlock switches.
- Door is not securely closed.
- You waited too long - open and close door to wake it up!
- Problem: No heat but otherwise normal operation.
Possible causes:
- Blown fuse in HV transformer primary circuit or HV fuse (if used).
- Bad connections (particularly to magnetron filament).
- Open HV capacitor, HV diode, HV transformer, or magnetron filament.
- Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
- Defective HV relay (not commonly used).
- Problem: Timer and light work but no heat, cooling fan, or turntable
rotation.
Possible causes:
- Defective (lower) door interlock switch or door not closing fully.
- Faulty relay or triac.
- Problem: Fuse blows when closing or opening door:
Possible causes:
- Defective door interlock switch(s).
- Interlock switch knocked out of position.
- Misaligned door.
- Problem: Loud hum and/or burning smell when attempting to cook.
Possible causes:
- Shorted HV diode, magnetron.
- Burnt carbonized food in or above oven chamber.
- Shorted winding in HV transformer.
- Frayed insulation on HV wiring.
- Problem: Arcing in or above oven chamber.
Possible causes:
- Burnt carbonized food deposits.
- Exposed sharp metal edges.
- Problem: Fuse blows when initiating cook cycle.
Possible causes:
- Defective interlock switches or misaligned door.
- Shorted HV capacitor.
- Shorted HV diode.
- Shorted magnetron (probably won't blow main fuse but HV fuse if used).
- Defective triac.
- Old age or power surges.
- Defective HV transformer.
- Short in wiring due to vibration or poor manufacturing.
- Problem: Fuse blows when microwave shuts off (during or at end of cook
cycle).
Possible causes:
- Defective triac (doesn't turn off properly).
- Defective relay.
- Shorting wires.
- Problem: Oven heats on high setting regardless of power setting.
Possible causes:
- Faulty primary relay or triac or HV relay (not commonly used).
- Problem: Oven immediately starts to cook when door is closed.
Possible causes:
- Shorted relay or triac.
- Problem: Oven heats but power seems low or erratic.
Possible causes:
- Low line voltage.
- Magnetron with low emission.
- Faulty controller or set for wrong mode.
- Stirrer (or turntable) not working.
- Intermittent connections to magnetron filament or elsewhere.
- Problem: Oven heats but shuts off randomly.
Possible causes:
- Overheating due to blocked air vents or inoperative cooling fan.
- Overheating due to bad magnetron.
- Faulty interlock switch or marginal door alignment.
- Overheating due to extremely high line voltage.
- Stuck stirrer fan resulting hot spots detected by sensors.
- Problem: Oven makes (possibly erratic) buzzing noise when heating.
Possible causes:
- Fan blades hitting support or shroud.
- Vibrating sheet metal.
- Vibrating transformer laminations.
- Turntable or stirrer hitting some debris.
- Problem: Oven light does not work.
Possible causes:
- Burnt out bulb :-).
- Bad connections.
- Problem: Fans or turntables that do not work.
Possible causes:
- Gummed up lubrication or bad motor bearing(s).
- Loose or broken belt.
- Bad motor.
- Bad thermostat.
- Bad connections.
Did you find this Tip Helpful?
Can you Help with these Microwave Ovens problems?
Kenmore 80412 / 80414 / 80419 Microwave Oven
kenmore model 721.6365330
trying to put glass back into... Answer This...
Kenmore over the range...
1000 watts - model 721.63653300... Answer This...
Kenmore 80412
Kenmore 80412
I just purchased a Kenmore... Answer This...
Sponsored Links
Repair Service
Find Microwave Oven Repairman Near You:
Find Parts
