Tip & How-To about Computers & Internet
How to change the SSID OR the Display of Your Routers
Hi Friend,
Please follow the below steps to change the SSID or Display
Name of your Routers,
Step1: Connect the Router to any one of your computer with an Ethernet Cable
Step 2: Check whether you are able to see all the lights in the router
Step 3: Open an Internet Explorer,and type 192.168.2.1 and click on Enter button
Step 4: Now you will be able to see the Belkin Router Setup page
Step 5: On your left hand side,below Wireless,Click on Channel and SSID
Step 6: It will ask for password,dont type any thing,just click on Submit
Step 7: Now in the SSID,you can change any name as you wish and click on Apply Changes
Step 8: Now you will be able to see the New display name for your network
Regards,
Aysaam
Computers & Internet Logo
Can I change channel/frequency to get a stronger signal between the PC and the Belkin54g router? If so, how?
Hi i go your issue .......
You can change the channel and the frequency to get a better signal range ......
To promote this please follow the following steps
Step 1: Connected modem>>router>>computer
Step 2: Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3: Towards the left corner click channel and ssid under wireless
Step 4: on the left under wireless click channel and SSID
Step 5 :Change the Wireless channel to 6 and also you can change the frequency there
Step 6 : Change the SSID to a different name ( no Spaces )
Step 7 : Click apply changes
Step 8 : Now Scan and connect to this network ( Wireless )
If problem still presists please contact 24/7 belkin technical support 1800-2235546
Thanks with regards priya
Oct 06, 2010 | Belkin (F5D7230-4) Router (587009)
I'm trying to secure my wireless connection
Step1: Login to the router page.
Step2: Click on wireless on top second option.
Step3: Put your SSID(which would be the name of your wireless network)
Step4: Select the channel as 1,6 or 11 for greater range.
Step5: If you want the SSID to be broadscast(that means everyone withing the range of the router can see the SSID.) then check it as enable, else disable.
Step6: For putting security click on the "wireless security" option just below the wireless and select your option as WEP (as it is a easy way of encrytion) and than put your password.
Let me know if that helps.
**If this works please rate else let me know in case of further help.**
Jul 07, 2010 | Linksys Wireless-G WRT54G Router
Change the display network name
Hi Friend,
Please follow the below steps,
Regards,
Aysaam
May 12, 2010 | Belkin (F5D7633UK4A) Wireless Router
Unlock router
Hi ,
please follow the steps to fis your issue
Step 1 :Connect Router - Computer ( Wired )
Step 2 :Open RSP by typing 192.168.2.1 on the address bar of the internet explorer
Step 3 :On the left , Under wireless Click wifi protected setup
Step 4 :Leave the password blank and click SUBMIT
Step 5 : Disable it and click apply changes
Step 6 : On the left under wireless click security
Step 7 : Disable it and click apply
Step 8 :on the left under wireless click channel and ssid
Step 9:Change the ssid into a different name And click apply
Step 10 : Connect to this new name
please rate the service if issue resolve
Thanks for using Fixya
Apr 02, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
no network code for router want to connect my laptop to it
Hello friend,
i guess that you are talking about wireless code, in this case you will need to connect the laptop to the router via Ethernet cable to configure it and then unplug the cable and use the wireless.
so you connect the ethernet cable between the laptop and one of the ports on the router from 1 to 4. then access to the router web interface which is usually 192.168.1.1. then go the wireless tab and name your wireless access point and put a password to secure your network. After that you can unplug your Ethernet cable and use the wireless on your laptop to connect your router wirelessly.
Best Regards,
Oct 31, 2009 | Linksys Wireless-G Broadband Router
297 people viewed this tip
David Payne
David Payne
