Bicycle Accessories Logo
Tip & How To about Bicycle Accessories
I has to change my WTB Velociraptor 44/50 tyres last week due to age and wear bu
Posted by Owen Stephen DawsonOwen Stephen Dawson on Friday, May 14, 2010
I soon found out that the 44/50 on the tyre is a two-number system introduced by Wilderness Trial Bikes who make the Velociraptor tyres, and is called the GMS both sizes are in millimeters and refer to the size of the inflated tyre, I don't think that it was a popular sizing system I couldn't find much about it but this is what I found out.
  1. The first number is the width of the inner casing in this case 44mm
  2. The second number is the width of the outside tread 50mm
---------figure 1-----
These measurements are taken on a standard rim which is 20 mm wide at the bead-capturing point (inner measurement) , with a tyre inflated to 60psi (4 BAR) and maintained for 24 hours.
The recommended pressure range is from
40-75psi on most WTB tyres. Download the PDF on tyres sizes for all the WTB range.
NOTE: > 14.50 psi = 1 Bar
Common BSD (also in inches) vs Actual Wheel Diameter check out my GMS Tip HERE for more information on this critical Bead Size and Tyre size relationship
622mm (24.5") = 29" - Large MTB
622mm (24.5") = 28" - 700C
590mm (23.3") = 26" - Standard MTB
520mm (20.5") = 24" - Childrens MTB
451mm (17.8") = 20" - BMX
NOTE: The BSD of the tyre is always 15% smaller than the Actual Measured Wheeel Diameter
The WTB tyres also have one rotation for the front tyre the treads usually point in this direction and a rear tyre can be used in both directions depending upon its use either Dry Mud OR Cross Country Downhill
Read more tips from Owen Stephen Dawson
