Tip & How-To about Health & Beauty
How to make bar soap last longer
To make your bar saop last longer, remove soap from all packaging and them AIR out in the linen closet, spare room etc. Discard the soap bar boxes in different trash containers in your home for a quick freshen-up.
Health & Beauty Logo
how to change the flter
Turn off the unit and unplug it. Turn the air purifier on it's side and unscrew the locking mechanism (turn counter-clockwise) on the base of the unit. Remove the base assembly from the unit. Remove the filter assembly and find the seam of the pre-filter. Carefully separate the fastener and then remove the pre-filter from the HEPA filter.
Discard the filter(s) being replaced. Then remove the new filter from the packaging and discard the packaging and plastic. Carefully wrap the pre-filter around the HEPA filter so that the ends meet. Fasten the ends together with the fastener.
Place the filter assembly in the air purifier and reattach the base. Then tighten the locking mechanism. Turn the unit right side up, plug it in and turn it on.
You can find a pdf of the manual here: http://www.honeywellpurifiers.com/product/0-90271-50150-4.html .
I hope this helps.
Oct 03, 2010 | Honeywell 50150 Air Purifier
Opening suitcase
Yes, on the second floor there is a linen closet. Then you must go into the locker right next to the door and get the wire cutters from the tool box on the top shelf. I hope this helped. If you've moved past this point and you figured out a way to use that pen after dinner please sent me a tip.
Thanks!!!!
Feb 05, 2009 | Atlus Hotel Dusk: Room 215 for DS
No water or soap flow
Does liquid squirt out of the hose. If it does then probably the heater inside the handle asm. is clogged. Take out the two long screw that hold the top handle on and remove it, then near the bottom of the handle, near the bottom are 2 more screw to remove. Then the front of the handle asm. will come off, pull the 2 tubes off of the heater and check the inlets to make sure they are open. It gets clogged up from calcium from saop deposits, but when you are down with the machine, run vinegar and water mix thru to clean out the lines before you put it away. Let me know if this doesn't fix your problem.
Jan 01, 2008 | Bissell 1699 ProHeat Clear View Upright...
478 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
