Tip & How-To about Computers & Internet
How to remove AUTORUN.INF file from pendrive or block AUTORUN in PC
The Microsoft Windows Operating Systems use the AUTORUN.INF file from removable drives in order to know which actions to perform when a new external storage device, such as a USB drive or CD/DVD, is inserted into the PC. But there is large amount of malware-related problems associated with Microsoft AutoRun.
Follow the steps below to remove Autorun.inf from Pendrive:
1.) Open Notepad and do not write anything in it. Go to File > Save as autorun.inf
2.) Copy the autorun.inf file that you have created in the above step and paste it in your “Pen Drives”
3.) Remove your pendrive.
4.) Re-insert your PC. Now your pendrive is safe to use.
5.) Or simply use Panda USB and AutoRun Vaccine utility.
Computers & Internet Logo
AutoPlay - Windows XP
Autorun is a feature of Windows XP that brings up a screen with actions that the user can perform any time a storage device or piece of media is inserted into a computer. This feature can be disabled by changing a value in the system registry. If the Autorun feature is not working on your Windows XP system, fix the computer so that the Autorun options will be displayed when a USB device is connected.
Select the "Start" button and choose "Run." Type "regedit" (no quotation marks) and click "OK." Click on the key "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\NoDriveTypeAutorun" in the left side of the window. Right-click on the value "NoDriveTypeAutoRun" in the right side of the window. Select "Modify" from the menu. Enter "91" into the "Value data" box. Select "Hexadecimal" as the type. Click "OK" to enable Autorun on all types of drives, including USB devices. Close the registry editor and reboot the computer. Hope this helps.
Jan 10, 2013 | Computers & Internet
problem with windows xp
Sometimes it happens in windows XP that you are not able to open drives on your hard disk. When you double click on the drives icons or right click on the drive>>explore in My computer ,the drive does not open.
This problem is generally caused by most of the viruses which infect windows XP system. They block or restrict your access to any of the drives.
But don’t worry this is not a big trouble it can be fixed easily.
Fix:
Normally when a virus infects a windows system which causes a drive opening problem, it automatically creates a file named autorun.inf in the root directory of each drive.
This autorun.inf file is a read only ,hidden and a system file and the folder option is also disabled by the virus. This is deliberately done by the virus in order to protect itself. autorun.inf initiates all the activities that the virus performs when you try to open any drive.
Very simple . virus create some bad registry if you want to solve this problem then delet this registry
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion­\Explorer\MountPoints2
delete all drive from here
May 11, 2009 | Microsoft Windows XP Professional
autorun.inf virus prob.
go to start button and press run option type cmd type cd\  2. type c: and press enter
3. type attrib -r -h -s autorun.inf
4. type del autorun.inf
Apr 01, 2009 | Microsoft Windows XP Home Edition
unable to delete the autorun.inf
hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Feb 12, 2009 | Microsoft Windows XP Professional With...
412 people viewed this tip
David Payne
David Payne
