Tip & How-To about Audio Players & Recorders
How to bypass ipod lock system
I have figured out a stupidly easy way to bypass the screen lock on an iPod. Here's how the feature is supposed to work: You set a combination lock to keep someone from viewing your personal contacts and changing the song. This lock survives a reboot, and can only be reset if you dial in the lock code or plug it into the home computer to which the library is synchronized.
How do you bypass this in case you forgot? Quite simple. Just get another PC or Macintosh. If your iPod Nano is mac formatted, you'll need a copy of MacDrive to view the disk. Ensure that your system is set to view hidden files and folders; this is accomplished much more easily on a windows machine (explorer: tools > options > view > show hidden files)
Steps:
Mount the nano (plug it in)
Navigate to X:\iPod_Control\Device\ (where X is the drive letter of the iPod)
Find the file called "_locked" and open it with Notepad or TextEdit
There's your code.
OR... rename the file to _unlocked
Close Textedit/Notepad, and eject iPod from computer
my ipod is screen locked and now as i dont know the password i cant unlock it.since many days ive been tryin so many combinations but still it cant be unlocked. wat am i suppose to do????
Taken from the apple website.
http://support.apple.com/kb/HT1350?viewlocale=en_US
Unlocking iPod
You can unlock iPod in one of two ways:
  • Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
  • Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
  1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
  2. Connect your iPod to the computer that you want to be the primary computer.
  3. Open iTunes and synchronize.
Mar 05, 2011 | Apple iPod nano
How can i unlock my ipod nano 4GB
"Screen Lock" is provided by the iPod nano, iPod (5G), and subsequently released iPod models. Earlier iPods do not offer this feature.
In the Apple Support Site, Apple notes that the "Screen Lock" function:
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer . When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
May 18, 2010 | Apple iPod nano
how to unluck my ipod nano
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Jan 26, 2010 | Apple iPod nano
forgot the lock code?is their a bypass code!
Steps:
There's your code.
Jul 17, 2009 | Apple iPod MA446LL/A MP3 Player
ipod is open but i cant play any song..its lock .What will I do?
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally--not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Jan 03, 2008 | Apple iPod nano
269 people viewed this tip
 Grubhead
Grubhead
