Tip & How-To about Televison & Video
How to fix a no vertica drive problem.
Your projection TV works but the only visible part is a thin horizontal line across the screen. What happened and how do you fix it?
Your problem is that you have no vertical drive, only a small horizontal line across the screen. In older projection TVs this is usually caused by broken solder joints in the area of the vertical IC and over the entire board. It could also be caused by a bad vertical IC. Let's approch this problem one step at a time.
Disconnect the power. Remove the back cover. Remove the board with the vertical IC which is usually the board with the high voltage transformer on it and it is usually on the right side of most TVs. You can also identify the proper board by looking for and following the wires from the yoke which is on the CRT neck. There should be a yellow, brown, green and red. The yellow and brown are the vertical wires.
Before removing any wires mark them with a sharpie or a label maker. Just make sure that you will be able to reassemble the unit without mixing up any wires.
Usually the board in question is on the right. It will be the one with the flyback on it. The flyback looks like a small cylinder with about 4 large wires coming off of it. They will be red rubber and flexible. One goes to each CRT.
You will need to remove the entire assembly to get to the underside of the boards to solder the unit or replace the vertical IC. Sometimes removing the restraints will allow enough room to flip the board over and do the work without removing all the connectors and removing the board.
Once the underside of the board is exposed, solder all connections on the boards. Be careful not to bridge any connections. Test the unit for proper operation.
If the unit still does not work properly replace the vertical IC. It usually begins with LA followed by 4 digits. It will be in the vicinity of the flyback probably towards the front of the board. The Ic will be attached to a large aluminim heat sink. Make sure that you do not bridge any of the circuits when soldering. Replace the IC, reassemble and test.
If things went well the unit should work ok.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Televison & Video Logo
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Our three year ol Samsung TV has dark horizontal lines across the top of bottom of the screen. It is getting worse
Welcome to fixYa!
When you see lines like these across your LCD, it indicates a problem with your monitor's electrolytic capacitors.A faulty filter capacitor in the power supply board (SMPS board) can cause horizontal lines across your monitor screen.Horizontal screen lines are one of the most visible problems I see in LCD monitors & TV's that are 3-7 years old. It can happen as much from heat, humidity & less-than-ideal operating conditions, as it can from fluctuating current supply or manufacturing defects.
The way to repair horizontal screen lines is by removing the capacitors from the printed circuit board (PCB) and testing them with a LCR meter.
If it shows zero, there's your confirmation that the specific capacitor needs to be replaced.
now if you can replace them your welcome but i wont suggest that , cause you may break it more....!
any ways do comment if it helped you in any manner!
Apr 30, 2011 | Samsung HL-R6168W 61" HDTV
Panasonic PT-47X54J Not working
I can't tell you how to fix this set, but I can tell you that its not a "lamp" issue as this doesn't have a lamp. Its a 3 picture tube projection TV. the three tubes are in a red green blue format, and average about $175 for each one, not including the labor to install them. your problem, may not be the tube, but just a power supply problem, but there is a chance it is.
Nov 21, 2008 | Panasonic PT-47X54 47" Rear Projection...
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
648 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
