Tip & How-To about Cell Phones
All nokia secret codes part3
Caution - starting from here the codes are "dangerous"
*#7370925538#
* # of res wallet # ... is to be deleted the code around the "wallet"! Input like normal telephone number (not in wallet code inquiry windows).
NOTE! Afterwards the "wallet" is empty, can again be put on however with new code.
*# 7780 # The "original attitudes" and telephone re-establishes is again started (an appropriate inquiry and it follow before must the sicherheitscode be entered).
NOTE! Afterwards various "attitudes" are away - among other things these:
·1 Points of entrance (Provider dependent points of entrance and attitudes)
·2 Bluetooth attitudes
·3 Favorite
·4 Allocation of the two keys (beside Navi keys) in the main menue
·5 Profiles are "neglected" (as with distribution) - still there however new bell tones, etc. are...
·6 SMS/MMS/E Mail attitudes
·7 Logos and spielstaende (allegedly) also deleted...
Programs, calendars and contacts, etc. not changed...
Also the sicherheitscode remains.
This putting back goes also via menu under "attitudes - general - original telephone once.".
*# 7370 # Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.)
NOTE! If the Akku to 75% are loaded at least, Akku do not only accomplish during the procedure under any circumstances remove! The procedure takes some minutes (approx. 3-4), is absolutely waiting!
This is "only" a soft format... Hard format with "green, 3, *"... see below.
Green, * 3 Hard format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET.
Proceeding: Equipment switch off, which keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
If that does not function, then equipment for 1 hour switch off, Akku so for a long time rausnehmen and again try.
"only" virtual the memory is generally cleared - genuine formatting can take place only in a Nokia service center, if the Fash is deleted there and/or new L.G. is installed.
Cell Phones Logo
i need security code
Hello I will be very happy to assist you please follow this steps carefully
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings - security settings -user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser
This is all the information I have for youPlease if this information was helpful please rate it is very important so I can help others.
thank you for using Fixya.com where you save hundreds
Mar 13, 2012 | Nokia Classic 2700 Cell Phone
I forget me my nokia 6300 securty code
HI
Feb 17, 2012 | Google Computers & Internet
7610 wallet code forgotten
*#7370925538# ... is to be deleted the code around the "wallet"! Input like normal telephone number (not in wallet code inquiry windows).
Aug 02, 2010 | Nokia 7610
160 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
