Tip & How-To about Cell Phones
Okia secret codes part-2
All n*# 06 # Seriennummer/IMEI indicates (actually also a GSM is code - see further below)
*# 0000 # SW version announcements (e.g. V3.42.1, 16-10-03, Nhl-10)
*# 2820 # Bluetooth (BT) device address indicate
xx # Directory quick access (xx = storage location and afterwards lozenge e.g. 24 #)
A/from key Short pressing for menu for switching between profiles
Menu key Long pressing for "task manager" - switching between active programs (with "C" key programs can be terminated.)
Menu quick access Over in the menu e.g. to point 3.1 arrive simply 31 enter (if the third symbol a file is opened is for these and then in it started the first Programm/Icon).
Autostart go around When switching on of the Handys on to the pin inquiry the key "ABC" (pin) comes the whole time keeps pressed - this is to ignore (allegedly) the autoinitialization programs.
# Do not switch between different lines (AS)... goes e.g. with Austrian ONE Handys (see nose cunning). I could not try out however also, since I did not have 2 lines on the SIM map.
12345 ... is according to standard set the Nokia nokia-Sicherheitscode.
0000 ... is according to standard those (with Vodafone windshield frame section) set 2te pin and that standard net code/password
With D1 the standard net code is the last 4 numbers of the card number without HLR e.g. 99999234-5/55 - > 2345
0 - for a long time press If one the "0" in the main menue for a long time presses those homepage of the standard WAP connection is called.
Cell Phones Logo
Mintak kode pengaman hp nokia RM 1110. Code.059w6h8.imei.1.3578/02/0645088/6.imei.2.3578/02/06/459089/4
tolong beritahu saya kode pengaman hp nokia 215 dengan model : RM-1110
code: 059w7p2
imel 1 : 357803/06/093140/5
imel 2 : 357803/06/083141/3
lupa kode pengaman
Feb 07, 2016 | Nokia Cell Phones
nokia 6133 v 05.60 17-11-06 rm-126 (c)nokia imei 358968014416784
If the phone is tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Oct 18, 2011 | Nokia 6133 Cellular Phone
Security code for Ultra MP3
IMEI: 353777005605288
key: 37769
IMEI: 356640005158475
key: 57142
Aug 28, 2008 | Nokia 6600
151 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
