Tip & How-To about Cell Phones
All nokia secret codes
Tips / undocumented functions:
- At the top of the main-menu and every folder, the keys 1 to 9 are shortcuts to the icons 1-9
- A shortcut on the left menukey in standby-mode will take more time to open than a shortcut on the right menukey. Reason: The left key is also used for the keylock so it shortly waits for pressing the * button.
- While writing text press and hold "#" to switch between Alpha mode and Number mode. You can also press a key long to insert its number.
- In standby-mode, press and hold 0 to launch your wap home page.
- If you have your keylock activated just press the on/off button to turn on your backlight to look at the time when it's dark without having to unlock the keypad.
- To keep the backlight on, run Torch (freeware), press and hold the Menu button and go somewhere else on the phone.
- To check your current firmware version simply type *#0000# in standby screen.
- To check your IMEI (International Mobile Equipment Identity) type *#06# in standby screen.
- To check your Bluetooth device address type *#2820# in standby screen.
- Start up in Safe Mode (no 'auto start' apps will be running): Hold down the pencil key when you turn on the phone and hold it on until you have to enter your PIN code.
- Format the phone memory by typing *#7370# in standby screen.
- In standby mode,
45# + dials the number on your sim in memory slot 45.
50# + dials slot 50 and so on
Cell Phones Logo
can't find my Google icon
Fix All My Computer Shortcut Links
Computers often use shortcut links to make it easier for users to locate and open files.
These links are commonly placed in a folder easily accessible to users, such as a desktop folder.
When a shortcut is created, it is given directory information and an icon.
If the file associated with a shortcut is later moved, the shortcut may fail to locate the file.
When this problem occurs, you need to update the shortcut's directory information.
This process is often automated by operating systems, but in a some instances, you need to repair shortcuts manually
Right-click on a broken shortcut link's icon.
Select the "Properties" option. Locate the "Target" box and copy its information into your clipboard using the Ctrl and C keys.
Open the "My Computer" folder on your computer and paste the target information into the folder's address bar using the Ctrl and V keys.
If the address bar is not viewable, you may need to enable it in the folder's settings.
Find address bar options in the "View" menu under "Toolbars."
The file's target path folder will open.
Locate the file in the target path folder.
If the file is not present, the target path is inaccurate and likely the cause of the shortcut link error.
Locate the file in its correct folder.
Browse folders or search for the file by typing the file name into the "Start" menu.
After finding the file, open the properties of the shortcut link icon again.
Copy the file's correct path, from the containing folder's address bar, and paste it in to the "Target" box, replacing the incorrect link.
Another way to find a file's target path is by right clicking on the file and selecting Properties.
You can find accurate target information in the "Target" box, provided the icon is the original file icon and not a shortcut.
Aug 11, 2013 | Computers & Internet
start
Jun 07, 2013 | IwantSoft Free Keylogger
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
my desktop shortcuts open with search results page only
1.
Right-click Start, and then click Explore.
2.
Locate the folder, file, or program in the Folders directory, and then click the item to open it.
3.
Click the icon representing the item.
4.
Click File on the toolbar, and then Create Shortcut on the drop-down menu that appears.
5.
Right-click on the shortcut icon that is created.
6.
Choose Send To from the drop-down menu, and then click Desktop (create shortcut) on the submenu that appears.
Jan 09, 2009 | Acer Aspire™ T180 PC Desktop
Samsung Omnia - Main Menu Function key gives a shortcut error.
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Dec 09, 2008 | Samsung SGH-i900 Omnia Unlocked Cellular...
151 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
