Tip & How-To about Computers & Internet
Unaccessible harddrive, or password protection on
If you cant format or access a harddrive due to encryption,corruption,password or other reason,
WARNING! THIS WILL ERASE ALL FILES ON YOUR DRIVE!
The last effort can be to try to boot up your computer in DOS-mode,
with a software that totally wipes/overwrites the disks sectors.
The harddrive must be direct connected to the motherboard,
not by anykind off usb-cord or any usb-port.
using a freeware program called "KILLDISK".You can find the software if you go to WWW.GOOGLE.COM and search for KILLDISK.
it totally wipes your harddrives sectors, eliminating all corruptions.
It can also be used for erasing confidential information from drives.
If this was helpfull, Please vote!
Computers & Internet Logo
Dear Team Today when i try to use my CRUZER U3 (8GB) I GET MESSAGE "you have reached the maximum number of failed password attempts ..................................................................... ....................................." and I get only option to "Erase" the information i have important file in the cruzer . i need help i want those files they are very important. please help me =( Thanks Afshan
Each U3 smart drive comes with a pre-defined number of login attempts. When you have only 3 attempts remaining, you will receive a warning message to prevent losing your data unnecessarily.
SanDisk does not have any method to bypass the password security feature on Cruzer U3 flash drives. SanDisk has not built in any back door or password reset methods. If the password feature is enabled and you exceed the number of incorrect password attempts, the drive will lock. Once the drive is locked there is no way to unlock the drive or gain access to the data stored on the device. You can only select the format feature, which will perform a secure erase (drive wipe) and data recovery will NOT be possible. U3 Cruzer flash drives which are password protected use 128bit AES encryption for data security
http://kb.sandisk.com/app/answers/detail/a_id/191
Sep 23, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
XP sees CD/ROM for WD1600JS USB Harddrive. (It's
Try to format the drive!
WARNING! This procedure will erase all files on the drive! Please vote!
Feb 18, 2010 | Western Digital Caviar SE WD1600JS...
Multisystem ulility plus supporting OS
If you use the utility that comes with the drive, you will be able to access all of your files and folders that you encrypt on the drive privided that you don't forget your password. If you want to make sure that the drive is protable (can be used on multiple systems), you need to make sure you enable Travel Mode with the Seagate Manager software. You must remember the password in order to access your files.
Jul 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dell Media Direct Cannot access hard drive due to bitlocker encry
Sounds like the hard drive was encrypted prior to the upgrade to SP2.
If that's the case, you may have created a password during the encryption process. See this reference to recall the steps for encrypting a hard drive with Bitlocker.
Follow the steps for unlocking your hard drive and you should be ok.
If for some reason, you never encrypted the hard drive and do not have a password, then the encryption may have been caused by some bug in the upgrade and you should contact Microsoft to resolve.
Jul 02, 2009 | Dell XPS M1530 Notebook
Vista wants me to format my external harddrive.
Can you access this drive on a non-Vista system? If so, try the Simple Tech WWW site for a diagnostics program?
There are also a number of other software programs that can detect and mark the bad sectors or locations on your drive as bad.
Once those sectors are marked (at the FAT Table) as bad Vista may allow you to access that drive again. IF it does, copy everything available to a DVD. Now reformat the drive but DON'T trust it.
Bottom line is that I personally would not trust that drive again with ANY data that is important to me... I hope you will agree with me. If you decide to use it anyway please backup to two locations or drives!
Good Luck!
Feb 22, 2009 | Western Digital My Book Essential Edition...
133 people viewed this tip
David Payne
David Payne
