Tip & How-To about HP OfficeJet 7410 All-In-One InkJet Printer
ALLIN ONE 7410 SCANNER PROBLEM
Flat bed glass top scanner works perfectly fine.
ADF Feeding scanner puts red lines on document shown on preview computer screen and will print same if I save or print the document.
HP troubleshooting tips only covers the flat screen scanner gass top.
Called HP and they suggested I either buy a replacement printer for $250.00 or it would cost $400+ to repair this one.
I removed the ADF (three small screws) and cleaned the small section of glass underneath and reinstalled the ADF component.
WORKS FINE NOW !!!
HP REPAIR PEOPLE ARE A RIP OFF ! DO IT YOURSELF AND LEARN MORE ABOUT YOUR MACHINE BEFORE WASTING ANY MONEY !!!!!
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Why are pages scanning with lines running through them, but printing perfectly fine?
Try cleaning the rollers. Usually you have to remove the cartridge to get to the rollers that moves the paper.
May 02, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
Canon MX850 printer - ADF copy has black line on it
Hello, my name is Steve,.
This is a common problem and an easy fix.
If you lift the ADF / top cover assembly up, you will see a small narrow piece of glass next to the flat-bed glass.
Ths is called a "Slit-glass". The only purpose is to read content from that point by the scanner, The Scanner will sit in the underside of it.
It is dirty. Wipe this with glass cleaner and a soft lint-free cloth. you may need to do this several times. Concentrate the part of the glass were this image problem is just by the orientation of the document you are installing with the direction of the document you are passing through the ADF.
It will take several attempts, but with each try, make a new test from the original document, unyil the problem disappears.
I believe this will solve your problem, Best , Steve
Mar 10, 2009 | Canon PIXMA MX850 multifunction InkJet...
hp 2840 laser printer
are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there.
Nov 12, 2008 | HP LaserJet 2840 Printer
copying on my 7210 hp all in one
are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there. if you are using the flatbed portion of the scanner, clean the larger glass on the scanner and as before let it dry before trying to use the copier again and then test the copier.
Sep 18, 2008 | HP Officejet 7210 All-In-One InkJet...
2,482 people viewed this tip
Seeker5211
Seeker5211
